49 5 Speed Overdrive - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-08-2011, 08:01 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
My memory says that the overdrive ratio on these was only 19% or so. I was interested in swapping a 337 and overdrive 5 into an F-2 until I tried to find a truck transmission that would fit in the F-2. I still have the big Lincoln 337 I picked up years ago.
  #32
Old 06-08-2011, 09:43 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Quote:
What transmission gearing would the Lincoln have? 3sp, 4sp, auto?
  #33
Old 06-11-2011, 08:59 AM
38 coupe's Avatar
Quote:
Lincoln used the GM 4 speed hydromatic behind the 337 in passenger cars. Also optional was overdrive in the form of a Borg-Warner T85-R11 setup that gives 29% overdrive. I guess you could have purchased a Lincoln with just the column shift three speed T85 without overdrive, but I have never heard of one.
Went drag racing again today. pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-15-2016 12:59 PM
First build / 74 250 2wd dthut 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-16-2016 09:28 PM
A little ID help would be great kylebegger 1957 - 1960 F100 & Larger F-Series Trucks 11 05-02-2015 09:07 AM
Prodigy P2 Brake Controller rdalley All Other Items for Sale 0 02-14-2012 01:16 PM
PCV Elbow enriched&beyound Modular V8 (4.6L, 5.4L) 0 03-10-2011 07:00 AM
Tags
1949, 1956, 5speed, antique, direct, drive, f8, ford, overdrive, pictures, speed, tractor, truck, trucks, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
