49 5 Speed Overdrive - Page 2 - Ford Truck Enthusiasts Forums
Old 05-02-2010, 08:35 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
At least im not the only one who talks before he thinks.
Old 05-03-2010, 08:06 AM
old uhaul old uhaul is offline
old uhaul is starting off with a positive reputation.
I think you would need a bellhousing from something like a 54-56 f750/f800/f900 to bolt up to the '54 239.They had the same pattern as the y block and accepted the large 5 speed trannys.
Old 05-03-2010, 09:19 AM
denverslim denverslim is offline
denverslim is starting off with a positive reputation.
I've still got a rebuilt and running 337 Flattie here in Denver, if anyone is interested. Also I've got the above trannie to go with it...slim
Old 05-04-2010, 02:39 AM
mOROTBREATH mOROTBREATH is offline
mOROTBREATH is gaining momentum as a positive member of FTE.
Well now that we are all on the 5-spd OD topic:
Would any of the three(light, medium, and heavy duty) 5-spd OD(not direct drive) trans from the 1956 model year--once again only in the larger trucks--fit physically into an F-100? Is there a chance they'd bolt up to the 223 I-6, or the 272?
I'd love to have one because their 2nd gears are low enough to act as a 1st, and since they are synchronized, it would not only make for easier downshifts to "1st(2nd), but would also help cruising on the highway with the OD 5th gear.
I think the 5-spds only came hooked up to the 302 or 332 in '56 though.......
Old 05-04-2010, 07:03 AM
I believe the bellhousing from a '56 332 has the same pattern as the regular 272 y block,so it should be no problem to mount the big truck trans to a 272
Old 05-04-2010, 02:18 PM
^^Good to know! Thank you.
Old 03-12-2011, 10:38 PM
C-700 C-700 is offline
C-700 is starting off with a positive reputation.
Quote:
Originally Posted by fifty-two_f1 View Post
Will this five speed fit a 54 f600 with a 239 yblock? are the bell housings the same?
I have the bellhousing for the y block ford to use this 5sp OD transmission including the flywheel, disc, pressure plate and clutch fork. I also still have the trany if anyone is interested. Ford used the y block with the parts to use this transmission in the 700 for a few years and anyother of their HD tranys of that era.
Old 03-13-2011, 06:13 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
5od
Oh yea I have a truck just waiting for an 5 OD allthough being non sync
I dont care. These are ment for F7 & 8s. so anybody thinking about
F6 & under there will be driveshaft issues and pilot bearing issues, and
I dont think smaller Y blocks or something has a big enough crank bore
for the big roller bearing pilot I think the input shaft is around .750 or
larger and memory thinks the U joints were spicer 500X way bigger than
F6- F600s. So I will be interested. Sam & Sons
Old 03-13-2011, 12:50 PM
Should be able to have a pilot bushing machined to fit if needed and any drive line company can put a drive shaft together with the needed ends. The Y blocks in the 54 F700 used a different pilot bearing then the larger truck engines, don't know the difference but shows a different part number.
Old 03-14-2011, 12:38 AM
I even have the drive shaft for that transmission. Interested? PM me
Old 06-03-2011, 12:23 AM
1953f350 1953f350 is offline
1953f350 is starting off with a positive reputation.
I dont know if you guys are familiar with the 60s internationals, but they used 3 and 4 speed trans that should bolt right up to a ford. I have a 63 c1300 with a straight 6 and it has 4.88s and is SLOW. It has a three speed and a five speed with overdrive would be sweet for that truck. and if it did not bolt up as planned then it should go in my 54.
Just wondering if you ever attempted that swap? I have a line on a 5 speed from a 68 IH for my 53 F350 and was just going through the motions to see if it was similar? Any way to reference it?
Thanks
Brian
Old 06-03-2011, 11:25 PM
I never did the swap because I never had the 5 speed to begin with. I am still hunting one close to me!
  #28
Old 06-03-2011, 11:51 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Quote:
Thanks
Brian
I would measure the input shafts before commiting to buying. (T34)
  #29
Old 06-04-2011, 02:50 AM
Quote:
Its on the bench so I can take some measurements,anybody have the numbers on a tock 4 speed anywhere to compare? I am blown away by the knowledge on this site so I figure it never hurts to ask. It would be good to know if these are an option for our trucks.
What I know so far is that in an IH,you have to swap the flywheel and use a different bellhousing than you do with the 4 speed when converting. They are also available in a 5 speed direct and a 5 speed over.
B
  #30
Old 06-04-2011, 09:40 AM
havi's Avatar
Its on the bench so I can take some measurements, anybody have the numbers on a stock 4 speed anywhere to compare? I am blown away by the knowledge on this site so I figure it never hurts to ask. It would be good to know if these are an option for our trucks.
What I know so far is that in an IH,you have to swap the flywheel and use a different bellhousing than you do with the 4 speed when converting. They are also available in a 5 speed directT36 and a 5 speed over.T34
B
Even in an IH, the 4sp. and 5sp. use different bellhousings. The flywheel is huge, will dang near knock you out if ya ain't careful....don't ask how I know, lol. Anyway, a smaller Ford flywheel will be needed to fit a Ford bellhousing. (and starter)
It would be an interesting swap to see.... won't be easy, I have a feeling.
Went drag racing again today. pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-15-2016 12:59 PM
First build / 74 250 2wd dthut 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-16-2016 09:28 PM
A little ID help would be great kylebegger 1957 - 1960 F100 & Larger F-Series Trucks 11 05-02-2015 09:07 AM
Prodigy P2 Brake Controller rdalley All Other Items for Sale 0 02-14-2012 01:16 PM
PCV Elbow enriched&beyound Modular V8 (4.6L, 5.4L) 0 03-10-2011 07:00 AM
Tags
1949, 1956, 5speed, antique, direct, drive, f8, ford, overdrive, pictures, speed, tractor, truck, trucks, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
