Trailer battery relay
Sorry I don't have my manual in front of me, but the fuse you're looking for is under the hood, driver's side up on the firewall. It's a maxi-fuse and your owner's manual should tell you which one and the size (amps) required. Often even though the wiring is there, the fuse wasn't installed.
The maxi-fuse is there, the mini is there, the wire at the plug is not hot. In the manual it says a relay should be located near master cyl. I have found a relay box behind glove box with 2 relays in it, one big one small. Spoke to r.v. installer and 2 ford shop formans, they all think it should be near master cyl. as-well but it's just not there!
Looking at my manual which should also cover yours, there is a fuse and a relay under the hood:
16, Trailer Tow Battery Charge, 30 AMP (located in the pwr distro box)
39, Trailer Tow Battery Charge Relay (located in one of two small black boxes between the PD box and the brake master cylinder.)
KCBS Smoker
1999 to 2016 Super Duty
13
01-09-2019 02:50 PM
kidoo
06-03-2013 01:18 PM
