push throttle/push brakes it stalls..PLEASE HELP!
Old 01-21-2013, 06:37 PM
apprentice guy's Avatar
apprentice guy
apprentice guy is offline
Have not tried that.this thing has me puzzled.i thaught it was a fuel pump issue.i replaced it.but the truck runs fine in the day time.as soon as the temp drops.in the mornings when i warm it up.press on the brake and it stalls.i removed the fuel filter install a presure port and it goes to o when the brake is pressed.any ideas
Old 02-08-2013, 05:06 PM
apprentice guy
no it does not stall when i turn stering wheel from side to side.
Old 08-04-2014, 06:11 PM
AFmechRRivers's Avatar
AFmechRRivers
AFmechRRivers is offline
Same problem
I'm currently working on a 2005 Ford F-350 that's showing the same symptoms as above. I see that Kimyward says that he replaced the CPS. Was it with an improved aftermarket version or an OEM part? I'm stumped, this truck:
-isn't popping any DTC's
-shuts off if it is revved to 2800rpms and you let off the pedal
-shuts down sometimes with sudden braking, especially after revving
I was originally assigned this vehicle to replace a wiring harness, which I did. I've checked connections, inspected engine PIDS with the IDS diagnostic program, and swapped the ICP sensor. If anyone has some insight please let me know.
Thanks
"Pop the hood, DAMN WE'RE GOOD!"
Old 08-04-2014, 06:18 PM
apprentice guy
My was on a 05 f350 V10 I redid all my engine grounds and had the computer refreshed and bbc.co problems solved
Old 08-04-2014, 06:24 PM
AFmechRRivers
quick question
Thanks for the swift reply, but what does bbc.co mean?
Old 08-04-2014, 06:49 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Thanks
Check your fuel pressure. You need as very MINIMUM of 50 psi for healthy injectors. The only time I've ever had this happen was from low fuel pressure.
Old 08-04-2014, 06:55 PM
apprentice guy
Sorry I meant I redid the engine grounds and the dealer reflashed the computer and problem was solved.hope this helps out
Old 08-05-2014, 02:25 PM
AFmechRRivers
Worked
I replaced the camshaft postion sensor, and the truck seems to be fine now. Thanks for the assistance.
Old 08-05-2014, 02:30 PM
apprentice guy
Am glad things went well for u this is a great site.
Old 01-07-2017, 02:48 AM
jmccart's Avatar
jmccart
jmccart is offline
Having similar issues, dies when hitting the brakes or turning the wheel. If I raise rpm up slightly it doesn't do it. Possible cam sensor?
The following users liked this post:
9Dark6
1999 to 2016 Super Duty
15
11-29-2022 06:14 PM
NateDu
02-06-2018 07:53 PM
jamers
04-27-2017 02:47 PM
RedDevil460
08-12-2016 06:07 AM
Ryan Simpson
15
04-12-2016 06:53 AM
Quick Reply: push throttle/push brakes it stalls..PLEASE HELP!
