push throttle/push brakes it stalls..PLEASE HELP!
Have not tried that.this thing has me puzzled.i thaught it was a fuel pump issue.i replaced it.but the truck runs fine in the day time.as soon as the temp drops.in the mornings when i warm it up.press on the brake and it stalls.i removed the fuel filter install a presure port and it goes to o when the brake is pressed.any ideas
Same problem
I'm currently working on a 2005 Ford F-350 that's showing the same symptoms as above. I see that Kimyward says that he replaced the CPS. Was it with an improved aftermarket version or an OEM part? I'm stumped, this truck:
-isn't popping any DTC's
-shuts off if it is revved to 2800rpms and you let off the pedal
-shuts down sometimes with sudden braking, especially after revving
I was originally assigned this vehicle to replace a wiring harness, which I did. I've checked connections, inspected engine PIDS with the IDS diagnostic program, and swapped the ICP sensor. If anyone has some insight please let me know.
Thanks
"Pop the hood, DAMN WE'RE GOOD!"
Thanks
Thanks
Thanks
The following users liked this post:
NateDu
02-06-2018 07:53 PM
jamers
04-27-2017 02:47 PM
RedDevil460
08-12-2016 06:07 AM
Ryan Simpson
15
04-12-2016 06:53 AM
