push throttle/push brakes it stalls..PLEASE HELP! - Page 2 - Ford Truck Enthusiasts Forums
Old 01-21-2013, 07:37 PM
apprentice guy apprentice guy is offline
apprentice guy is starting off with a positive reputation.
Have not tried that.this thing has me puzzled.i thaught it was a fuel pump issue.i replaced it.but the truck runs fine in the day time.as soon as the temp drops.in the mornings when i warm it up.press on the brake and it stalls.i removed the fuel filter install a presure port and it goes to o when the brake is pressed.any ideas
Old 02-08-2013, 06:06 PM
no it does not stall when i turn stering wheel from side to side.
Old 08-04-2014, 07:11 PM
AFmechRRivers AFmechRRivers is offline
AFmechRRivers is starting off with a positive reputation.
Same problem
I'm currently working on a 2005 Ford F-350 that's showing the same symptoms as above. I see that Kimyward says that he replaced the CPS. Was it with an improved aftermarket version or an OEM part? I'm stumped, this truck:
-isn't popping any DTC's
-shuts off if it is revved to 2800rpms and you let off the pedal
-shuts down sometimes with sudden braking, especially after revving
I was originally assigned this vehicle to replace a wiring harness, which I did. I've checked connections, inspected engine PIDS with the IDS diagnostic program, and swapped the ICP sensor. If anyone has some insight please let me know.
Thanks
"Pop the hood, DAMN WE'RE GOOD!"
Old 08-04-2014, 07:18 PM
My was on a 05 f350 V10 I redid all my engine grounds and had the computer refreshed and bbc.co problems solved
Old 08-04-2014, 07:24 PM
quick question
Quote:
Thanks for the swift reply, but what does bbc.co mean?
Old 08-04-2014, 07:49 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Thanks
Check your fuel pressure. You need as very MINIMUM of 50 psi for healthy injectors. The only time I've ever had this happen was from low fuel pressure.
Old 08-04-2014, 07:55 PM
Sorry I meant I redid the engine grounds and the dealer reflashed the computer and problem was solved.hope this helps out
Old 08-05-2014, 03:25 PM
Worked
I replaced the camshaft postion sensor, and the truck seems to be fine now. Thanks for the assistance.
Old 08-05-2014, 03:30 PM
Am glad things went well for u this is a great site.
Old 01-07-2017, 03:48 AM
jmccart jmccart is offline
jmccart is starting off with a positive reputation.
Having similar issues, dies when hitting the brakes or turning the wheel. If I raise rpm up slightly it doesn't do it. Possible cam sensor?
intermittent stalling at acceleration. jamers 1999 - 2003 7.3L Power Stroke Diesel 8 12-07-2016 06:43 PM
Truck Starts, then dies: Also dies while driving RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 9 08-12-2016 07:07 AM
engine stalls after warming up for 10-20 minutes gary.aderhold 1999 - 2003 7.3L Power Stroke Diesel 50 12-11-2015 06:48 PM
Ranger 1990 vs New owner (DTC 14 & others) AderisKD Ranger & B-Series 14 10-08-2015 03:12 PM
E350 with no throttle response at all Scoop1376 1999 to 2016 Super Duty 2 02-22-2008 04:48 PM
Tags
1999, 3vze, brake, brakes, dies, duty, explorer, f150, ford, press, push, pushing, stalls, super, throttle, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
