'99 F150 Coolant leak. Heater core? - Ford Truck Enthusiasts Forums
Old 04-30-2010, 05:24 PM
Moto7387 Moto7387 is offline
Moto7387 is starting off with a positive reputation.
My '99 F150 has had a coolant smell in the cab, which seemed to get worst with the heat on. Today I drove it home, parked it, and went outside later to find a decent size puddle of antifreeze. The early symptoms seemed tipical of the heater core but the floor in the truck never got wet, and the heater core was replaced 3 or 4 years ago by the previous owner. I got under the truck and looked and can't see where it's leaking from, but it's dripping off the heat sheild for the exhaust. Will a bad heater core leak outside of the cab? Thanks for the help.
Old 04-30-2010, 05:40 PM
n3up's Avatar
n3up n3up is offline
n3up is starting off with a positive reputation.
It can, the coolant will come out of the A/C condensate drain.
Old 04-30-2010, 10:55 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
at the front of the motor, look down behind the alternator and see if there is antifreeze laying in the valley of the motor.
Old 04-30-2010, 10:56 PM
steve(ill)'s Avatar
Old 05-01-2010, 09:50 AM
Hmm, I actually replaced the alternator wednesday and didn't notice any coolant, but I'll check again today. If I don't see anything I guess I'll loop a heater line between the motor ports and bypass the heater core, that should isolate it to a motor leak or heater core leak. Thanks for the replies - Jake
Coolant Leak In Cab treverd 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-30-2016 10:31 PM
No heat issue on 7.3L NavyMIDN08 1987 - 1996 F150 & Larger F-Series Trucks 2 12-31-2011 05:20 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 08:55 AM
heater not blowing hot air Propr801 1987 - 1996 F150 & Larger F-Series Trucks 6 12-23-2008 06:49 AM
heater not blowing hot air Propr801 Cooling, Heating, Ventilation & A/C 1 12-19-2008 07:51 PM
Tags
1973, 2005, bypass, cab, colant, coolant, core, expedition, f100, f150, ford, heater, leak, leaking, leaks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
