header ques. 1994 f250 5.8 - Ford Truck Enthusiasts Forums
Old 04-30-2010, 04:27 PM
daddyhock daddyhock is offline
daddyhock is starting off with a positive reputation.
Hey guys, need some help
my 351 windsor/5.8 has the stock exhaust manifolds that i want to change over to a pair of shorty headers.
the problem i have been having is finding headers that have the threaded
bungs on them for my emissions... my driver side header has a threaded pipe that is off the back(next to firewall) passenger side has threaded pipe that turns upwards and has something attached to it ..but all the headers i find dont look like they have these...any help would be great..
Old 04-30-2010, 05:59 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Where does the fitting on the driver's side lead to? None of my Lightnings or my current '92 F350 w/5.8L engine has any attachments on the driver's side. There is a EGR pipe fitting on the passenger side.
Old 04-30-2010, 06:08 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Does your truck still have a cat or even more important do you have emissions tests to pass? If not then remove the smog plumbing and install the headers you want.
Old 04-30-2010, 06:15 PM
The pipe on the driverside,turns and goes behind the head and is hooked to something back behind the head and intake
Old 04-30-2010, 06:37 PM
yes it still has the cat. it also has a smog pump,and no i dont have any emmissions tests where i am. but i dont want to have to take the smog pump off?i would assume my truck has the california emissions.
Old 04-30-2010, 07:05 PM
MCarlson MCarlson is offline
MCarlson is gaining momentum as a positive member of FTE.
I just put the Bassani's on my Bronco. Too soon to tell exactly how much better everything runs or not but I can tell you they bolted in perfectly. Got the new y-pipe from them at the same time. You get what you pay for and installation wise I can say the Bassani set up was worth the money.
Mike
Old 04-30-2010, 09:21 PM
Conanski's Avatar
Quote:
The smog(air) pump does not have to come off if you remove the smog plumbing, you could just leave it there as an idler.
Old 05-01-2010, 06:54 AM
ok, if i take off the smog plumbing and leave the pump,wouldnt there be some kind of noise like pushing air coming from the smog pump?and if the egr is what is out of the passenger side exhaust manifold,all the headers i am seeing does not have a threaded bung for the egr either?
Old 05-01-2010, 10:03 AM
Conanski's Avatar
Not if you reattach the outlet muffler directly to the pump and leave the intake muffler as is. Those are the two cylindrical things on the passenger inner fender right behind the battery.
Smog legal headers for these trucks will have EGR and O2 bungs and some may even have the smog attachments. These bungs are clearly visible on these Ford Shorty headers for example. Do a search on the Summitracing web site and you'll see literally dozens of headers for this truck, most of them with these fittings.
Old 05-01-2010, 12:11 PM
@conanski those in the picture are exactley what i need,and those are the frrp..but they are 450.00 , i was wanting half as cheap..but if i cant find any cheaper i will go with those..all other pics on summit look like a un threaded tube out the front of the passenger side exhaust header, and they all look to big for my pipe to thread to...but thanks for all the help i think i just might go with the frpp. and my o2 sensor is just a few inches in front of my cat? if that helps
Old 05-01-2010, 02:16 PM
42x 42x is offline
42x is starting off with a positive reputation.
I believe Conanski has a photo of welding on a threaded bung to screw the O2 sensor into the headers. Pretty cheap fix.
The only things I would say about installing headers is somethimes the more expensive ones fit better. I picked up some inexpensive headers and had to massage (hammer and punch) the exhaust tubes around the nut area for several nuts. I had to put in studs to support some of the misc parts and pieces - ie the dip stick holder, fuel injection support brackets, smog housing...
The other thing I took away from this installation was not to bother with ceramic coating as the coating was compromised during the "massage". Pain to clean then paint with high temp.
Old 05-01-2010, 02:41 PM
Conanski's Avatar
You're shoping in the wrong place, they're only $329 at Summit. Those Ford shorties are stainless steel too so they'll last forever. Ford Racing M-9430-T58 - Ford Racing Hi-Flow Shorty Headers - Overview - SummitRacing.com
Painted Flowtech headers are much cheaper but you may want to check with them before buying to find out of the EGR fitting on this is threaded to accept the factory EGR tube.. Flowtech 91668FLT - FlowTech Headers - Overview - SummitRacing.com
Pacesetter headers are another brand a few guys have had good luck with.. PaceSetter Performance 70-1323 - PaceSetter Headers - Overview - SummitRacing.com
Old 09-04-2014, 05:19 PM
sainsane sainsane is offline
sainsane is starting off with a positive reputation.
smog and headers
I do have California emissions on my 96 f-150 5.8L I was hoping to get info with putting them on and removing the cats completely for better exhaust flow. Do need to have the computer re-flashed or what do you recommend
Old 09-04-2014, 07:03 PM
rla2005's Avatar
Quote:
Welcome to FTE!
Please start your own thread instead of tagging onto a 4 year old thread.
4.9L EFI Header Install Tips and Tricks Nathan Plemons 1987 - 1996 F150 & Larger F-Series Trucks 2 05-12-2015 06:15 PM
5.8 Headers: What should I do with the EGR? Big Sky Highboy 1987 - 1996 F150 & Larger F-Series Trucks 22 03-01-2015 06:30 PM
5.8L EFI 351W Headers? a11jack3dup 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 03-07-2010 05:32 PM
long tube headers that are kalifornia legal?? maschronic 1987 - 1996 F150 & Larger F-Series Trucks 23 08-01-2007 02:56 PM
headers, y-pipe, and cat for 5.8l moishlashen Exhaust Systems 6 10-22-2004 07:01 PM
Tags
1992, 1994, 50, 58, 75, egr, f150, f250, flowtech, ford, header, headers, install, legal, smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
