Trailer Running Lights Dont Work - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-30-2010, 11:36 AM
flairland flairland is offline
flairland is starting off with a positive reputation.
Hey guys, my trailer running lights have not been working for a while now on my 2001 F250 Diesel. I looked at the fuses under the hood and none seem to be blown. Any other places I should look? The problem started when the lights would sometimes work, and sometimes not, then one day they didnt work at all anymore. Please help!
Old 04-30-2010, 11:58 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
There are two fuses for trailer lights. One is called Trailer (I think) and the other is something like Trailer Relay. They're in the owners manual (if you still have it).
That being said, I've had the same problem in the past; blew both fuses, replaced them both... then, with good fuses, still had no running lights on the trailer.
Good Luck man.
Old 04-30-2010, 12:28 PM
Thanks. I looked at the fuses and swapped some relays around to see if that would work, still nothing. I dont have the owners manual but looked online at the fuse diagrams, but didn't help much. What did you end up doing to get them to work?
Old 04-30-2010, 01:23 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
You didn't mention, so have you checked for power at the trailer plug? If the lights were working periodically, it sounds like a connector problem. Maybe corrosion or a broken wire?
Old 04-30-2010, 02:23 PM
yeah, def check for power at the connector.
Me, I just trailered during the day. I also think my issue may have been specific to the trailer... (I hope)
Old 04-30-2010, 10:58 PM
kparret kparret is offline
kparret is starting off with a positive reputation.
Typically trailer light problems can be traced to a ground issue. You didn't mention if it was a 4-wire or 6 setup, but regardless there is a ground wire on both sides (vehicle and trailer). I'd start by checking the ground wire where it terminates on the trailer and make sure it isn't broken or corroded.
You can also try running a separate wire from a good trailer grounding point (no paint or corrosion - metal only) to a like point on the tow vehicle and see if that doesn't lighten things up
EDIT: Here's a good site that might help you out:
etrailer.com | Trailer Wiring Diagrams
Old 05-01-2010, 02:59 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The usual culprit is the ground connection at the trailer frame.
Old 05-01-2010, 07:30 PM
Thanks for the advice guys. I havent had a chance to dig any more yet, but I do know its not the trailer because I hooked it up to my friends truck and everything work.. so its something on my end, unfortunately. And yes, its a 6 way plug.
Old 05-02-2010, 09:26 AM
bobmiers bobmiers is offline
bobmiers is starting off with a positive reputation.
2 years ago I had a similar problem with my 2000 F250. Finally traced the problem to a corroded connector about 18 inches back from the trailer plug (up near the spare tire). Cleaned it and all worked OK. As a suggestion, check that out first... I spent a bit of time tracing power from the front of the truck - my running light relay is almost beyond reach behind and below the radio. Not easy to get to.
Old 05-02-2010, 11:39 AM
Quote:
Well.... you're half-way done then! Keep us posted.
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 08:25 PM
Trailer lights not working lakewood 1999 to 2016 Super Duty 7 04-27-2011 12:06 AM
No running lights on trailer Deerslayinrenek 1987 - 1996 F150 & Larger F-Series Trucks 3 06-25-2010 04:58 PM
Help on trailer lights... makomaker 1999 - 2003 7.3L Power Stroke Diesel 21 04-03-2010 04:22 PM
Help with trailer plug.... makomaker Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 23 02-24-2010 10:23 AM
Tags
08, 250, cheap, diesel, dont, escape, explorer, f350, ford, fuse, lights, running, trailer, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
