My overkill journey to sound deaden and proof a 05 F150 which is taken to the extreme
#31
Hi Silent,
If you can do us (me) a favor, could you comment on where is the biggest bang for the buck in terms of noise reduction after you test things out?
I was also in pursuit of quiet, but didn't want to go to the extreme of dynamating the entire truck.
I plugged up the 2 air vents on the back wall with a rag and found it quieted things down noticeably, but my ears popped every time I slammed the door shut. I wonder if that's why I seem to have air noise from the top edge of the windshield now when driving at freeway speeds as I'm sure the windshield was being blown outwards every time the door shut.
I ultimately took the rags out so I can have stale air exit the cabin with the windows up.. As a result, there's quite a bit of noise coming out the seatbelt holes and behind the rear seats
The doors and maybe door seals seem to be the next place where noise is coming in. Not sure how to deal with that. I think there's noise coming through the speakers since the only thing between the speakers and the inside is the outer skin of the door.
I've thought about adding a 2nd line of door gasket along the outer edges of the door to make a better noise seal, but these experiments are still on my to-do list.
Anyways, any suggestions/recommendations for a silent-wanna-be would be welcome
#33
#34
No, I've been really busy working and have not had very much extra time. However, I'll post a few new pics, of the progress I have been able to make, in the next couple of days. I'm dying to finally enjoy the fruits of my labor. There's just a lot of labor left, before any fruit can be bared. Tomorrow, I'm going to start recovering my dash and all of my interior trim. That way, when it's able to be reinstalled, it'll be ready to rock and roll. I'm stoked to see how the black leather and charcoal suede will look, instead of the ugly *** plastic. You guys should be getting a steady diet of pictures, this next month.
#35
sounds good!
I have started to do my SD this week. some vibration damper on the doors, then a 1/8 1lb per sq ft mass loaded vinyl with a 1/8 closed cell decoupler then another layer of closed cell foam on the inside of the door. I have done the rear doors so far. there is a slight reduction in road noise from behind the driver, hope it is going to pay off in the long run.
#36
If your floor isn't done, that is some of the reason. If it is done, clog and barrier over your cabin pressure vents, behind your backseat. That's where you'll notice the biggest difference in road noise. Before you commit 100% to it, try it, then take your truck for a drive. If you're not convinced, then simply remove it. It's kind of hard to get rid of road noise, when you have two 3"x7"ish holes near and above the exhaust. Sound will always find the easiest and weakest path to penetrate. That's why EVERYTHING needs to sealed and have equal coverage, with extra attention payed to the problematic areas. That's why I went to the extent I did. I didn't see any point in spending all that money and skipping the firewall. To me, it's the most important place to soundproof because the engine is only inches away and the front tires are right there. With my big mudders howling down the highway, I couldn't see another way to eliminate that noise. Along with, my system will sound that much better, not having to compete with all the exterior noises. If I can eliminate 3db or road noise, my stereo will sound the same at half volume as it did at full volume, before. If you think about it in those terms, that's a significant difference. Also, it's important to fill every cavity, in your truck, with foam or cotton insulation.
#38
The doors still close just fine. Sure you might not be able to give it the girly, flick of the wrest, shut anymore, but a manly push does the trick every time. It's not like the cabin is completely air tight anyways. In theory it sounds problematic, but the reality of it is, it's a mute point.
#39
#40
I'll gladly do that when I'm finished. I wish I'd have thought about that before I started this craziness. Then I'd have a definitive, before and after. It'd be a hell of a lot more then only a 3db difference, though!!!
#43
#45
