A/C blows cold then gets warm. Any ideas? - Ford Truck Enthusiasts Forums
Old 04-29-2010, 11:04 PM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
I was wondering if anyone has had this issue and knows what's going on. I can turn on my a/c on a relatively cool day and it blows cold. After a while it gradually begins to blow warmer air. On a hot day it struggles to even start out blowing cold air and quickly gets warm.
Last summer it would do this and drip water on the passenger's floor mot from just underneath the dash. A shop that I had work on the issue at that time said some portion of the A/C system had mud or dirt in it that caused it to condense moisture internally and mix with the "dirt" and created a mud like consistency. This supposedly reduced the effectiveness of my a/c causing it to begin blowing warmer air. His solution was to spray water inside the blower area up next to the passenger's side firewall through an access point created by removing some kind of electrical sensor or relay. I'm not sure what the electrical component really is though.
This "fix" only worked for part of the day I got it back from the shop then it started to get warm again and dripped water on passenger floor mat. So far this year I haven't had to use the a/c much, but it really doesn't work worth a darn on days above 75 and I haven't experienced the drip on the floor mat this year either.
Thanks in advance for any suggestions.
Drake
Old 04-29-2010, 11:10 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Drake
Drake, look here http://www.ford-trucks.com/forums/95...ml#post8832377
it sounds like you need to check the airgap in your compressor clutch, and maybe replace the clutch. Mine was doing the same thing for the past few weeks. replaced clutch and all is well.
Old 04-29-2010, 11:12 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
I would check the evaporator drain first
Dirt in the evaporator core (or other air restriction) could cause icing causing it to blow warm air but it should drain on the ground not the floor
I haven't looked at this truck but some you can pull the blower motor and wash the evaporator core
Old 04-29-2010, 11:20 PM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
N V US Lawn Care is gaining momentum as a positive member of FTE.N V US Lawn Care is gaining momentum as a positive member of FTE.
Brandon and Ray...x2 from me...also may want to search for the Max A/C "ranger" mod...
Old 04-30-2010, 12:14 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Old 04-30-2010, 11:49 AM
Quote:
Originally Posted by SpringerPop View Post
Marv, that was a great plast from the past...i went out and tested mine, and guess what...???...the clutch didn't re-engage itself, but did when i tapped with the screwdriver...i guess i get to work on my truck......i suppose i need to rep you yet again for good info...
EDIT: dang rep police won't let me rep ya' Pop...i guess i need to spread the love around first...
Old 04-30-2010, 11:53 PM
Thanks for the thought, just the same.
Glad I could be of help to you.
Pop
5.4 V8, heat/ a/c works for only 20-30 min.HELP twb12 2004 - 2008 F150 8 02-08-2017 02:43 PM
2003 ford e250 4.2l A/C PROBLEMS F-WhiteThunder 1968-2013 Full Size Vans 4 06-07-2014 06:02 AM
Cold Ac when Idle and Hot when driving? Any Ideas partslady 1999 to 2016 Super Duty 2 05-14-2014 12:31 PM
2002 navigator rear a/c blows cold then warm jeffrey5679 1997-2006 Expedition & Navigator 2 05-08-2013 09:29 AM
A/C warm and hot ezgoing101 Explorer, Sport Trac, Mountaineer & Aviator 2 08-05-2007 10:45 AM
Tags
2001, ac, air, automotive, blowing, blows, cold, cool, f150, f250, f350, ford, strts, truck, warm, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
