Valley pan - Ford Truck Enthusiasts Forums
Valley pan
Old 04-29-2010, 11:22 AM
mabc926's Avatar
mabc926 mabc926 is offline
mabc926 is starting off with a positive reputation.
Valley pan
My valley pan drain plug is missing....where can I get a new one or what else can I use.....it is just a bolt with RTV around it?
Old 04-29-2010, 11:40 AM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
hmmmm, thats a new one. I didnt know they needed plugs, guess mine is missing too. Let me see, the guys at ford sell them and so does a parts store here called lordco. similar to all the states parts stores. They have the "gasket" and the kit comes with silicone, a rubber grommet for the cdr hole but nothing else. Does it need to be plugged? Should it be? Ford cant seem to figure that one out, anyone?
Old 04-29-2010, 11:45 AM
mabc926's Avatar
That's all mine came with, valley pan and CDR grommet, but then a saw the extra hole and started looking around and found out that's the valley pan drain and on autozone.com's repair guide it says there is a valley pan drain plug, just by looking it looks like a bolt just screws in the hole but I don't know
Old 04-29-2010, 11:58 AM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all
The "Drain bolt" is the retaining bolt that holds down the valley pan. It is a broached 3/8 drive hole with a small hole to drain water or fuel from the valley. It's located in the rear center of the pan. On an original pan may be harder to locate the bolt because it's probably filled with gunk.
Old 04-29-2010, 12:02 PM
mabc926's Avatar
Thanks crewdually!
I'll just go run out to lowe's and get a bolt to fit.
Old 04-29-2010, 12:18 PM
well **** maybe that is where a lot of my "mess" is coming from. That would explain a lot!
Valley pan Turbo grommet Dodge/Cummins Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 03-07-2013 10:46 PM
pcv conversion/ valley pan ? cbass139 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-07-2010 09:37 AM
460 valley pan Voh Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 12-12-2006 03:37 PM
Problems with Fel-Pro MS90618 intake manifold gasket 1977_250_460_C6 Performance & General Engine Building 4 12-02-2004 08:54 PM
Valley Pan Gasket coolmint94 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 30 03-11-2004 11:15 PM
Tags
400, 69, 73, 94, deisel, diesel, drain, excaust, f250, ford, homemade, liter, lordco, pan, parts, plug, removing, valley, vally
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
