6vdc to 12vdc
6vdc to 12vdc
Technically speaking there is no such thing as a DC transformer of anykind be it step up or step down. Transformers are strickly AC. There is probably some kind of electronic device that could take the DC, change it to AC, step it up with a transformer, and then change it back to DC.
6vdc to 12vdc
"Kioolt" is absolutely right. If you connect a transformer to DC, it'll turn into a smoke bomb right before your very eyes. The devices that convert DC votage to a higher DC voltage are often referred to as inverters (although that term usually applies to "DC to AC" units). There are units available that do what you want. They would either work like "kioolt" said (DC to AC, step up, & back to DC), or they would ELECTRONICALLY increase the DC voltage. If you do some "Electronics" searches on the web, you'll find some outfits that make such units. I've seen a few around.
Uzumati
04-03-2019 09:04 PM
Idaho Highboy
02-01-2017 07:26 PM
jusjoe
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
19
06-21-2015 05:41 PM
travelingman55
11-04-2012 10:36 AM
ilbigmike
07-14-2009 03:07 PM
