Official NCFTE motorbike club!?
#338
Is it starting and idling ok?
Where is it bogging down? As soon as you crack the throttle or somewhere in the upper revs?
Have you checked the fuel filter or tank for debris? Do you have a manual petcock or vacuum assist? Hate for you to have to pull out the carbs if it's just a piece of trash in the filter.
Well it's obviously been awhile since I've changed a tire on a bike. Took me two hours to take the wheel off the bike. Remove the old tire. Install the new one. Then put everything back on. In the past I could usually do it under an hour start to finish. I still have to do the rear this weekend. About an hour into the process I was about to throw a tire spoon into the wall.
#339
It's random, started by happening cruising in 5th, but now will happen in every gear, but it's very random. It'll run great for 30 miles then all of a sudden will bog like it does when I need to go to reserve.
Gonna pull the tank and check the filter this weekend if I get a chance, my petcock is manual, no vacuum to it. Not a 100% what it is, I ran some carb cleaner threw it and gonna run a little more and see if that helps.
#340
#341
#342
I pulled the tank yesterday and swapped out fuel filter, I also cleaned the battery connections up. Still ran bad so I was pulling the plugs again and noticed a drip. My thermostat is leaking right down on one of the coil packs. The leak was over the one that had the really bad looking plug when I changed them. So I ordered a new O ring for that gonna pop it apart this weekend and clean it up so I can throw it back together when the new O ring comes in.
#343
Well I fixed the thermostat housing where it was leaking but alot of antifreeze was spilled over the coils and stuff when I pulled it apart so I had to hose it off. Rode the bike about 50 miles this afternoon and it ran real rough at first. The further I went the better it got though, hoping that fixes it but I'm wondering if there isn't a issue with the coils that's letting the moisture in though.
#345
