7.3 DOES'T HOLD OIL PRESSURE
I NEED HELP, I HAVE A 95 7.3 DI AND I CHANGE A INJECTOR THE OTHER DAY. AND REMOVE ALL THE OIL THAT LEAK INTO THE CYLINDER , I GOT THE MOTOR TO RUN FOR ABOUT 5MIN THEN I SHUT IT OFF TO REPLACE THE VALUE COVER. WHEN REPLACE THE VALUE I HEAR OIL DRAINING BACK INTO THE PAN AND WHEN E TRY TO RESTART THE TRUCK THE OIL PRESSURE FOR THE INJECTOR WILL NOT HOLD IT PRESSURE AND IF IT START I HAVE TO HOLD THE PEDAL ALL THE WAY DOWN TO THE FLOOR TO KEPT IT RUNNING.
shay9165
10-11-2014 12:26 PM
funzjb1
26
03-22-2010 09:37 PM
jtownes14
17
05-21-2008 03:16 AM
