building a bad ass 302! - Ford Truck Enthusiasts Forums
Old 04-28-2010, 10:41 PM
pats302's Avatar
pats302 pats302 is offline
pats302 is starting off with a positive reputation.
building a bad *** 302!
i got a 96 f150 standard cab short bed
its got a 302
it has an a/m air intake and a exhaust upgrade (just a muffler)
it has a 4" suspension lift and 33"tires soon to be 35's
WHAT CAN I DO TO MAKE IT ONE OF THE BADEST TRUCKS ON THE ROAD!!
headers? cams? heads? borekits? maifolds? what can i do?!!??!
Old 04-28-2010, 10:47 PM
94MustangGT's Avatar
94MustangGT 94MustangGT is online now
94MustangGT is starting off with a positive reputation.
Gears, heads, cam, headers. Yep 300 BHP should be easy. Gotta' love the domestic small block.
On the other hand, a stroker kit would be nice, but maybe not worth it. Regearing the 4WD will sap some funds...
Old 04-28-2010, 10:48 PM
pats302's Avatar
ok so gears heads cams headers, give me brands and examples and suggestions
Old 04-28-2010, 10:49 PM
pats302's Avatar
how about LATTER BARS haha
Old 04-28-2010, 11:44 PM
PIKE's Avatar
PIKE PIKE is offline
PIKE is starting off with a positive reputation.
460+ and never look back
Old 04-29-2010, 12:46 AM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Quote:
It's ladder bars and what do you want this thing to be?
Old 04-29-2010, 12:52 AM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
o.O he wants it to be a fire truck LMAO....
evidently he wants some superb traction for those 35's
Old 04-29-2010, 02:08 AM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
Quote:
This is the question to end all other crazy dead-ends and cubic dollar mistakes.
Since it wasn't specified, I'll assume that the goal is to make this truck as fast as possible without regard to practicality, fuel milage, sustainability, ease of maintenance, or any other "kick-knack" reality check that we face when selecting parts and planning upgrades:
-Contact Boeing and obtain a RS-27A first-stage rocket left over from the Delta II program;
-With minor bodywork and some wind tunnel research, affix said rocket true to parallel to the plane of motion, compensating for the weight of the apparatus;
-Fuel up!
-Hang on!
I recommend ladder bars to assist with the suspension geometry shortcomings during the launch, and you might want to prepare yourself for the 4.5g's that are inevitable once the rocket achieves full speed. That'll teach 'em at the red light!
Old 04-29-2010, 02:24 AM
TorqueKing's Avatar
On second thought, if you don't have access to a large cache of liquid oxygen and hydrazine, you should probably warm-over that 302.
Again, echoeing zxwut, it all depends on what you want out of the vehicle.
-If you want to pull the motor, do a CHP 347 kit, or even safer, do an intermediate 331-stroker kit.
-Upgrade the cylinder heads if you are at all serious about power. I recommend AFR 165's for 302 displacement or 185's for strokers. Alternatively, use Edelbrock's Performer RPM heads and a cam suited to match. Your power potential's "ceiling" will be determined by your heads more than any other factor.
Old 04-30-2010, 12:50 AM
zxwut?'s Avatar
It seems as though this went nowhere, just as I figured it would.
Old 04-30-2010, 03:12 AM
TorqueKing's Avatar
Yeap, I think the Boeing rocket upgrade might be cost-prohibitive, but it would be the "baddest thing on the road".
93-octane being as magical a liquid as it is, there's just no comparison to hydrazine and single-digit-Kelvin-oxidiser. Oh well. It would've been perfect with those ladder bars. -TK
Old 04-30-2010, 09:21 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You guys are funny.... but then so is asking how to make a 302 into a badass truck motor.
Old 04-30-2010, 10:31 AM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
Yeah, but maybe we can make a mediocre-*** truck motor? Turbo, Nawz, Supahcharger...
Old 04-30-2010, 10:38 AM
Conanski's Avatar
Quote:
I think even that starts with a 347 stroker kit.. big tires requires big TQ and that requires more cubes. But if you're going to do that it's more cost effective to just start with a 5.8 and add the stroker kit. Then.. you got something that could be considered Badassed.
Old 04-30-2010, 12:00 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
I know how to make a 302 in a lite SB 2wd truck Bad *** , but with a 4x4 with 35s the more cubes the better ...Lew
Truck 302 to Mustang 302 H.O injector ?'s makingaZJ 1987 - 1996 F150 & Larger F-Series Trucks 13 02-19-2013 12:33 PM
69 351w into a 85 f150 w302 now... roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 07-19-2010 06:39 PM
302 in a bronco 2 Southernguy101 Bronco II 12 09-08-2005 08:06 AM
1973 ranchero swapping with 1978 302 engine ranchero73 Ranchero & 1961 - 1967 Econoline 1 05-16-2004 12:40 AM
302 knock sensor 1ford Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-07-2004 07:43 AM
Tags
302, 99, ass, bad, badass, butt, f150, ford, headers, kind, mustang, sb, truck, trucks, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
