building a bad ass 302!
Old 05-04-2010, 09:03 PM
pats302's Avatar
pats302
pats302 is offline
whats a good tranny to have i aint enjoying this e4od i have...is it a c6 i should look into?
  #47
Old 05-04-2010, 09:09 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Nah, you can fit them in there. Lots of folks on here have done them. It takes some fabbing, but basically the driver's side header feeds over to the pass. side, then it's your choice of true duals down the pass. side, or y it into a larger single. Add cat and muffler as needed.
  #48
Old 05-04-2010, 09:21 PM
Conanski's Avatar
Conanski
Conanski is offline
Just put a shift kit in it... every automatic should get one. And here are some shots of the exhaust I built for my truck with longtubes, the front end is all mendrel bent 2.5" tubing and the catback is 3".
New Exhaust - a set on Flickr
  #49
Old 05-04-2010, 09:24 PM
Bayer-Z28's Avatar
Bayer-Z28
Bayer-Z28 is offline
Throw an LS3 E-Rod crate engine in it. 494/440 hp/tq STOCK AND it's emissions friendly! Mate it to a 6L80E. Puttin an LS* in my truck when the engine dies.
-Sorry... sorry.. had to.. I'm a GM Performance guy...
  #50
Old 05-04-2010, 09:43 PM
Conanski's Avatar
Conanski
Conanski is offline
Blasphemy!! Off with his cylinder heads.
  #51
Old 05-04-2010, 09:48 PM
Bayer-Z28's Avatar
Bayer-Z28
^ Haha... .. I'm Running ~480 flywheel hp on my "old" LS1 with heads and .650lift cam.. it get's 14 city/28hw. Better bang for the buck.. Same $, more powah!
  #52
Old 05-04-2010, 10:53 PM
Bob Gervais
I've just lost all faith in humanity.
  #53
Old 05-04-2010, 11:40 PM
nashaj's Avatar
nashaj
nashaj is offline
ok so gears heads cams headers, give me brands and examples and suggestions
Gears = 4.10 or lower
Heads = is money an object?
Cam = pick out heads first
Headers = Most say Pacesetters or Flowtechs for these trucks
  #54
Old 05-05-2010, 09:40 AM
jawilla's Avatar
jawilla
jawilla is offline
ditch the 302. although you can make alot of horsepower you will never get the torque out of it for a truck. go find a 351w out of alightning. that is the only way to find a 351w that is a roller motor. That way you can put your 5.0 roller cams (i.e. comp cams extreme energy 274 which are awesome in 351w) you will gain hella torque but not have to do a bunch of engine bay modifications. i have a 91 with a speed density 302 and i am fixing to swap over to a carbed 351w roller.
  #55
Old 05-05-2010, 09:56 AM
lew52's Avatar
lew52
lew52 is offline
The Lightnings are flat tappet SD motors not roller , the 94 & later 351 trucks were rollers .... Lew
  #56
Old 05-05-2010, 09:59 AM
jawilla's Avatar
jawilla
jawilla is offline
yeah the roller i have came out of the 97 up body style lightning
  #57
Old 05-05-2010, 10:00 AM
Bob Gervais
In that case it's not a 351.
  #58
Old 05-05-2010, 10:09 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
This made me lolz
  #59
Old 05-05-2010, 10:24 AM
Bob Gervais
Originally Posted by zxwut?
This made me lolz
I lmao'd for sure. I'm a little tired for the lolz today...
  #60
Old 05-05-2010, 04:53 PM
Conanski's Avatar
Conanski
Conanski is offline
What does the "z" in "lolz" stand for anyway?
Quick Reply: building a bad ass 302!
