I must be gettin old, 2 belts snap off my 90 superduty.It has 4 belts total, 5 pulleys, besides crank and water pump pulleys. I can't figure out how the power steering belt, ac compressor, and vac pump (on top of the motor) go on.Took the belts down , made those folks read the numbers off the belts .. O' wisdom from the clan help me!!!
I have another vac pump just to the left of the air compressor on top..... this super duty was set up to tow using air to release brakes, maybe why it has 2 vac pumps?
texasjack, sounds like you certainly have something different than the norm, with having the second vacuum pump. Does either your AC or your PS pump have a double pulley? The vacuum pumps don't take a lot of power to run, hence why they are often ran off a secondary pulley from another source.
The ac, both vac pumps,ps,ac are single groove. Of course, water pump and crank pulley are 3 groove.The 1st VP is below the alt,have that belt on. The 2nd VP is on the
left side on the ac compressor, maybe sitting a inch higher. Wish I could draw it on here...................
7.3 IDI, F-450. Well after looking at it maybe the belt goes around ac, then 2nd VP( since they are right next to each other) and back around crank and waterpump pulleys.
But the belt that snapped, bought exact size no.# doesnt fit.........................
