need advice for my 7.3 idi
hi guys iam the new owner of a 1993 f250xlt extcab 4x4 with a 7.3 idi and a zf5 it hasn't run since 2018 an the wiring is a mess i got it to light off this morning but i believe i have bad glow plugs and the previous owner passed away and his son let it sit and get vandalized and tried to get it to start so its got a manual glow plug relay system that works but it barley wants to start and dies immediately after starting it does need new return line o rings as they leak like crazy it has a new lift pump and injection pump but would the o rings cause it to die after start up or is it something else
If the leak is so bad that you can tell the return lines leak, that air intrusion will make starting the truck and keeping it reliably running neigh impossible. At this point, your glow plugs could be working fine, but the air intrusion could be preventing success.
This video is a great starting point for new owners -
Received 3,103 Likes
on
ok i just did the o-rings i used the #111s so hopefully no more leaks i greased them up during installation thankfully i didn't break any of the plastic cup things all the lines were good and pliable there was some rust on cylinder no 4 injector but it wiped off with a rag and i looked down each with a flash light they seemed clean
eBay has a "made in Germany" kit for pretty fair, maybe those are better.
You can also order those #111 in viton online pretty cheap. Most go to McMaster Carr? I think it is. I get them on eBay for roughly 10$/50 of them with free shipping just because I already have an account there..
If you want to crank it before the glow plugs come in to see if you fixed the air intrusion issue or need the truck, don't touch the glowplugs and just give it a whiff of ether. It doesn't take much, be easy on it and it won't hurt it.
Ether isn't the enemy, the man behind the can is...
If you still have air intuition, check the filter head as the ones with the heater in them (7.3 style) are known to leak, also the little short piece of hose at the mechanical fuel pump.
And if you don't know the condition of the shower heads (pickup boot) in the tank don't let it get below or even close to 1/4 or you'll run out of fuel...
Best of luck to ya, whatever wrenching you do, as long as you're willing it beats the hell out of a payment..nothing like something you actually own
Make sure the sending units don't have any pinholes in them. Also a good time to do the "harpoon mod" so your tanks fill easy. Not sure if it was an issue on 87+ but it was one the 83-86.
I wouldn't spend too much time on the cleaning if they look good.
If nothing else you know the motor runs, and the 4wd zf5 is worth good money. You could part it out and maybe make your money back or even then some depending on what you paid.
