1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
1999 Navigator Blend Door Woes....
Old 04-28-2010, 03:30 PM
illgorhythm's Avatar
illgorhythm
illgorhythm is offline
So it would appear that I have several problems right now. A: I am only getting hot air up front.The Vent/Max AC door does work. Everything works fine in the rear, hot, cold, etc... B: Im only getting air out of the defroster, will not change between vent/floor/etc. B is not really of concern to me, I can deal with that, but A is really starting to be a B****H! Im not really sure how to diagnose the problem either. Ive read in some posts about a code (1249 i think) but I dont have a check engine light on which I assume means the computer isnt throwing out a code?? Any help appreciated.
Old 04-28-2010, 03:47 PM
rtg143's Avatar
rtg143
rtg143 is offline
The defrost only is probably due to a vacuum leak, With no vacuum, it defaults to defrost for safety reasons. Check under the hood for vacuum lines loose, off or broken. As for the heat only, the blend door could be defective. With the engine off and the key on, turn the control from heat to cool and back while listening for the door to move. It's not very loud but you can hear it if you listen closely.
Old 04-28-2010, 03:51 PM
illgorhythm
no sound at all. silence.
Old 04-28-2010, 03:57 PM
illgorhythm
then again....
On second inspection i noticed a couple VERY faint clicks when adjusting up from 60-68 degrees, nothing after that up to 90 degrees. When I adjust back down from 90 I hear the same EXTREMELY faint clicks at 68-60. Appears to be directly behind temp control panel. Could just be some sort of relay, no clue.
Old 04-28-2010, 04:44 PM
rtg143's Avatar
rtg143
rtg143 is offline
There are no relays controled by the dial. It's probably the blend door motor. At least they are pretty easy to get to. It's in the center of thedash and behind the lower center panel and rear air duct.
Old 04-28-2010, 05:08 PM
illgorhythm
DOH!!
HAHAHAHAH!!!! Upon FURTHER inspection..... A: The blend door is INFACT broken (Dremel'd a hole in the plenum to get to it, SOOOOO much easier than taking apart the dash!). B: There is NO BLEND DOOR ACTUATOR IN MY VEHICLE!!! WHAT??? Apparently the previous owner ripped it out in an attempt to solve the problem and then walked away from it. I realized this when I stuck my finger down the hole that the blend door sits in and my finger went through the bottom. Anyone got a part number for this thing?
Old 04-28-2010, 06:14 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Old 04-28-2010, 06:59 PM
illgorhythm
Yeah HeaterTreater is where I got the idea to cut into the plenum with a dremel. Problem is they only supply the door, which is an absolute ripoff for $120.00 You can get a replacement door on ebay with a steel ring where the problem area is for around $25.00. I still need the actual actuator box.
Old 04-28-2010, 07:17 PM
illgorhythm
What the fripping heck?! I can find blend doors for this thing all day but I cant find the actuator!! AAARRRGH! Does anybody have a part number for the ACTUATOR/MOTOR ASSEMBLY?? PLEASE HELP!
Old 04-28-2010, 09:50 PM
thecardoc's Avatar
thecardoc
thecardoc is offline
Blend door part # 660-1677 at NAPA actuator / motor # 655-1969 at NAPA
Old 04-28-2010, 10:51 PM
illgorhythm
So heres the issue Im having, only because I dont want to buy a part and it not work. The part number you listed for the actuator/motor is specifically for a 02-03 navigator. Any search on any site for an actuator for a 98-02 navigator will ONLY yeild results for the door itself, not the actuator, even Ford OEM Parts sites DO NOT show a part number for the actuator. Its should be noted as well that the Navs had a digital temperature adjust, not a ****/potentiometer like the Expys, so I can understand if there is a SLIGHT difference between the two, But I am completely dumbfounded at the thought that NO site on the entire internet lists a part number for any 98-02 Navigator actuator/motor. Only for the door itself. Is it possible that there is any difference between the Expy actuator and the Nav???? C'mon FORD!! WTF!!!! IM SICK OF THIS DUMBF*&^%*NG NAVIGATOR! I CAN FIND ANYTHING I F(*)^&NG WANT FOR AN EXPY BUT NOT A NAV?!?!?!?! WTF!?!?!?!?!
Old 04-29-2010, 01:51 AM
alloro's Avatar
alloro
alloro is offline
First off, ease up on the caffeine, second Ford doesn't make the Navigator Lincoln does. Third, I found an actuator listed on my first attempt just by clicking the link to this forum's sponsor ...Y2KFORDPARTS.
www.partsguyed.com
Studawg
06-10-2020 06:32 PM
Rus01
1999 to 2016 Super Duty
05-30-2017 10:30 AM
cwilkins002
10-20-2016 10:15 PM
2003xcrsn4x4
05-29-2014 03:27 AM
f100beatertruck
07-29-2013 07:41 PM
Quick Reply: 1999 Navigator Blend Door Woes....
