95 f150 won't go into gear - Ford Truck Enthusiasts Forums
Old 04-28-2010, 03:23 PM
khardrunner khardrunner is offline
khardrunner is starting off with a positive reputation.
On the way to the school where I teach this morning it seemed a little tough to get the truck into gear. When I put it into reverse to back into my space it made a grinding sound.Needless to say it's still parked there and I can't get it into gear. Clutch action seems to be lighter than usual so I'm thinking a clutch issue. I thought the clutch was fairly new when I bought the truck, but did I just lose my clutch?1995 F150 300 ci m5od tranny
Old 04-28-2010, 03:33 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
First thing to do is check the fluid level in the clutch resevoir. If low on fluid look under the truck for any fluid leaks.
If the fluid level is low then try topping it up with brake fluid and pump the pedal and see if that helps.
Old 04-28-2010, 04:15 PM
I got the truck home by pumping the clutch several times (and doing that several times throughout the drive home).
There wasn't any fluid under the truck other than the normal couple of drips of oil.
The fluid resivoir was at about 2 inches below the very top of the resivoir (it's not supposed to be filled up to the top but I don't remember how high it's supposed to be).
I didn't see any leaks at all
Slave cylinder is toast??
Old 04-29-2010, 02:36 PM
If no fluid leaks under the truck it is very unlikely to be a bad slave cyl. More likely a bad master cyl., have a look at the firewall under the dash for a fluid leak where the clutch pedal rod goes through.
If you do replace the master cyl make sure you follow the instructions with the new one and bench bleed it.
Old 04-29-2010, 02:43 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
LazyK x2... make sure you take a good look around the firewall some leaks can be tricky to spot especuially when they are not dripping on the ground for you. do you know when the last clutch was put in (record or reciept)? It's possible the slave could be bad but anyone worth their mechanicle grit should have known to replace the slave...
Old 04-29-2010, 05:01 PM
fordmanbrad's Avatar
fordmanbrad fordmanbrad is offline
fordmanbrad is starting off with a positive reputation.
More than likely you've lost the slave cylinder, unless you are so lucky that its the master cylinder or an external leak. My slave went at 75K miles, as did a number of other people I know at about the same mileage. Its now leaking just a little bit at 185K miles.
There is a little groove in the master cylinder, about 1/2" down from the top, that indicates full. If the slave is leaking, it will be running out of the bell housing.
As you probably figured, its not a fun job to replace the slave cyl.
Clutch to the floor: please help CraigerF100 1987 - 1996 F150 & Larger F-Series Trucks 3 12-06-2016 04:04 PM
Clutch Issues? Vaunripped 1987 - 1996 F150 & Larger F-Series Trucks 3 08-15-2016 11:04 PM
95 f150 clutch issues green_95 1987 - 1996 F150 & Larger F-Series Trucks 0 08-20-2015 08:15 PM
Zf6 clutch problem arkredneck 1999 - 2003 7.3L Power Stroke Diesel 16 06-13-2015 07:51 AM
Clutch issue jrollins 1999 - 2003 7.3L Power Stroke Diesel 5 01-04-2013 11:13 PM
Tags
95, 97, clutch, f150, f250, fluid, gear, go, kick, low, park, shift, spd, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
