Reflash and programmer problems
Hello,
I posted a while ago about cold start issues and reflashing with the current FORD flash. I wanted to obtain the newest flash to see if it would cure my woes before I make the jump to synthetic since my current oil changes are free using DELO 15w40.....anyway....I run an old school Superchips 1704 that has treated me right since day one. My question:
Once FORD reflashes my rig will my Superchips programmer still interface with my truck or am I going to have to have Superchips reprogram it or buy a new programmer (I 've been wanting to buy an SCT with an EGR strategy removed from the programming since I have an EGR delete)?
Thanks for the help
Joe
Thanks for the help
Joe
Hello,
Thanks for the help
Joe
Thanks for the help
Joe
DSMMH
I recall someone posting that after a reflash from FORD it rendered their Superchips inoperable. I have been wanting to upgrade to an SCT with custom tunes for a while and it looks like I may have to anyway since my FCDP egr delete retained the egr for visual aesthetics but still throws a constant CEL due to it still being in the programming.
I just want to make sure that the current flash that I have been reading about is not going to kill my FICM....is this still the case?
Thank you for your help
Joe
Joe
Joe
Joe
Moyock,
As it stands, my tuner has the OEM flash stored in it's memory. What you are saying is that once I plug in the 1704 tuner (after the VXCF9 reflash) it will default the truck back to the originally stored stock program, therefore deleting the 100.00 new flash I have FORD install?
I think regardless of what is the cheaper way, I will be forced to purchase an SCT X3 with custom tunes. Im not sure when smogs are coming to CA but I hate looking at the CEL all day long. It will never go away until I have it removed from the PCM's memory.
Coincidentally, I have been away from the up to date board happenings and I know there is a favored programmer for the SCT X3 on this board.....who's programming should I go with?
Thanks for all the help!
Joe
Joe
Moyock,
Joe
Joe
