Headlight Wiring Diagram 02 F250 w/DRL - Ford Truck Enthusiasts Forums
Old 04-28-2010, 08:44 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Anyone have a source for a headlight wiring diagram for a 2002 F250 with DRL? I need to figure out why my headlights only work when they feel like it.
The DRL work, though sometimes I wish they didn't (truck came from Canada). Flash to pass and all the other lights and functions work. But intermittently, the low beam and high beam function quit working. I drove home at 11:00PM last night with the markers and DRL only.
With the wiring diagram I have, I am leaning towards the switch or a loose wire behind it. This diagram doesn't have the DRL, and the fuse numbers don't match the manual, so I don't think I have the right one.
Old 04-28-2010, 09:23 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Go to autozone and register(it's pretty painless with no side affects that I have noticed). Then plug in your truck and then click on "vehicle repair guides" Then click on wiring diagrams. They have really good factory type diagrams for your year truck.
Old 04-28-2010, 11:00 AM
thomabb's Avatar
Found it. This is a great resource. Thanks.
Old 04-28-2010, 01:48 PM
thomabb's Avatar
Well, the switch seems to be working. I am going into the column to check the multifunction switch tonight. I have a bad feeling about this one . . .
Old 04-28-2010, 05:04 PM
rtg143 rtg143 is offline
rtg143 is starting off with a positive reputation.
It probably is the switch. Here are the DRL diagrams.
Old 04-28-2010, 08:56 PM
thomabb's Avatar
I found a loose wire in the column. I think it is the wire for the door open/key in ignition chime. When I touched it to a ground, I could watch the lights go out. Right now I have it outside the column and taped off. The only thing that doesn't work now is the chime.
I am no electrician, but I'll be damned if I can see on the schematics how those two circuits interract. When it was grounding out, it would interrupt the headlight power from the turn signal switch to the fuses. Finding it was pure luck.
Old 04-28-2010, 09:43 PM
At least you got it working. You can bypass the DRL by using the above diagrams. You connect the red/yellow to the red/black on the DRL module, (disconnect from DRL), and the DRL is bypassed.
Old 04-29-2010, 08:56 AM
thomabb's Avatar
I thought pulling the fuse would disable the DRL? That's my next project.
Old 04-29-2010, 09:23 AM
That's right, fuse #6.
Help with new halogen headlights? comsupany 1999 - 2003 7.3L Power Stroke Diesel 14 05-16-2016 12:56 AM
2008 Expy headlight/fog light wiring diagram JSDSM 2007 - 2014 Expedition & Navigator 1 05-28-2015 09:41 PM
DRL not working yssup 1997 - 2003 F150 2 12-29-2014 05:01 PM
Headlight relays + DRL's JockD 1999 to 2016 Super Duty 1 04-07-2009 09:59 AM
Low Beam Headlights Don't Work bawbaw Electrical Systems/Wiring 7 07-31-2006 09:51 PM
Tags
1996, 2002f250, 2005, diagram, diagrams, diesel, f150, f250, ford, headlight, headlights, heaflight, plug, wiring, wiring diagram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
