Mechanic for E350 Ambulance
Does anyone know of a good mechanic that works with ambulances (E350)? I have an old one I converted to run on used vegetable oil, but the engine won't start or cuts out. It feels like the diesel is not getting to the engine (nothing to do with the veggie oil line going into the engine). I've had it in a local shop in Laurel (between DC and Baltimore) several times, but they can't seem to fix it. Thanks for any mechanic tips!
I would start with the glow plugs/module. I had a '92 that had a problem starting and it had 4 bad glow-plugs. Replaced them and no more problems.... If I remember correctly, they can be tested with an ohm-meter. Have you asked about this up in the 7.3 forum? Lots of experts there..... here's a link https://www.ford-trucks.com/forums/forum117/
Here's alink to the glow plug troubleshooting section. https://www.ford-trucks.com/forums/9...le-system.html
There used to be an AWESOME diesel mechanic at Crystal Ford in Silver Spring named Mike, and the service writer was Rich. I don't know if they're still there, but it is definitely worth calling over there to see. I was wracking up MAD miles on my 7.3 and was in there 2 or 3 times a month for basic services and Mike caught a few potential issues while they were very minor before they became major fixes. I know they work on ambulances and RVs
Jerky's_06 F350
10-02-2015 12:12 PM
BossGasser
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-29-2014 08:25 PM
