Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 04-28-2010, 01:16 AM
daithi daithi is offline
Garage is empty, add now
daithi is starting off with a positive reputation.
Mechanic for E350 Ambulance
Does anyone know of a good mechanic that works with ambulances (E350)? I have an old one I converted to run on used vegetable oil, but the engine won't start or cuts out. It feels like the diesel is not getting to the engine (nothing to do with the veggie oil line going into the engine). I've had it in a local shop in Laurel (between DC and Baltimore) several times, but they can't seem to fix it. Thanks for any mechanic tips!
  #2 (permalink)
Old 04-28-2010, 06:10 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Try contacting Shaun, fire240. He works evenings, so may not be on until late afternoon. He lived in/near Dundaulk. He may or may not be able to help you.
Has it been running on the veggie before - or was it just converted? What year is it? Is it a 7.3 - N/A or turbo?
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 04-28-2010, 06:51 AM
Thanks, Bud. It is a 1989 Ford E350 with a 7.3. I had the veggie tank put in last year, when I bought it. It already had problems starting up, but it has gotten progressively worse.
  #4 (permalink)
Old 04-28-2010, 08:21 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
I would start with the glow plugs/module. I had a '92 that had a problem starting and it had 4 bad glow-plugs. Replaced them and no more problems.... If I remember correctly, they can be tested with an ohm-meter. Have you asked about this up in the 7.3 forum? Lots of experts there..... here's a link http://www.ford-trucks.com/forums/forum117/
Here's alink to the glow plug troubleshooting section. http://www.ford-trucks.com/forums/90...le-system.html
__________________
  #5 (permalink)
Old 04-28-2010, 09:12 AM
racsantina's Avatar
racsantina racsantina is offline
racsantina is gaining momentum as a positive member of FTE.
There used to be an AWESOME diesel mechanic at Crystal Ford in Silver Spring named Mike, and the service writer was Rich. I don't know if they're still there, but it is definitely worth calling over there to see. I was wracking up MAD miles on my 7.3 and was in there 2 or 3 times a month for basic services and Mike caught a few potential issues while they were very minor before they became major fixes. I know they work on ambulances and RVs
__________________
Life is measured in minutes, but it is judged by moments
DNA makes relatives, but LOVE makes families
The gas pedal is the one on the RIGHT!
  #6 (permalink)
Old 04-28-2010, 09:41 AM
glruff's Avatar
glruff glruff is offline
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
When was the last time you changed fuel filters?
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
  #7 (permalink)
Old 04-28-2010, 03:28 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Quote:
the bio diesel needs to be heated a bit 1st before it will combust properly. some people run a return line through the other tank, to pre heat the bio. after starting on the regular diesel, and heating the bio tank, then switch over. you will use a boat load of fuel filters on the bio,unless you filter it before putting it in the tank. most people run a 2nd set of filters before the filter that's on the engine. Bud is right about the glow plugs, that needs to be right before the engine will start. you need to also check for air leaks at the return lines, the orings get brittle over time, and create a air leak. hope this helps
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
  #8 (permalink)
Old 04-28-2010, 03:48 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
,,,and here's the link to the sites bio/veggie forum.... Bio-diesel, Propane & Alternative Diesel Engine Fuels - Ford Truck Enthusiasts Forums
__________________
Tags
1989, 1996, 73, ambulance, e350, econoline, ford, forum, information, literengine, md, mechanics, recall, trucks, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
