MAF Sensor on 7.3 diesel? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-28-2010, 12:14 AM
polestter24 polestter24 is offline
polestter24 is starting off with a positive reputation.
Question MAF Sensor on 7.3 diesel?
Hello,
I have 02 F250 7.3 diesel. Recently installed K and N intake. Runs great fuel mileage improved however after having it on for about a week my emission light is now on. I read many threads talking about oil getting on MAF and creating this problem...where can I find the MAF? Does anyone have a picture to post showing what and where it is? Any help will be appreciated!
Old 04-28-2010, 05:21 PM
Question ANY HELP OUT THERE?
HELP!
Old 04-28-2010, 08:31 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
7.3 does not have an MAF sensor, so that isn't the problem.
We'll need to know what code it is setting to help, otherwise there are several hundred things that will turn the check engine light on.
Jay
Old 04-28-2010, 09:09 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. Having the exact code would be helpful. Not all code readers are compatible with the 7.3 (ignore all those 96 and up claims). Maybe you mean the MAP instead of the MAF?
Also, pay very, very close attention to the inside of the intake tube between your new K&N and the turbo. The first time you see any signs of dust in there, switch to a different filter. We've read about several dusted turbos and even dusted engines because the K&N does not filter well enough in front of our turbo.
Old 04-28-2010, 09:22 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Jay
Old 04-29-2010, 05:23 PM
Code P0676
Thanks for the info...Pulled the code yesterday...The code that came up was P0676 which i think is a glow plug. How long should glow plugs last...Thanks again for the help.
Old 04-29-2010, 07:17 PM
bunklash's Avatar
bunklash bunklash is offline
bunklash is gaining momentum as a positive member of FTE.
Welcome to the forum.
Here's a link to another thread about this code: http://www.ford-trucks.com/forums/76...ighlight=P0676
I wouldn't think this code would set off an Emissions light, but....
I second the motion to put the K&N on Craigslist.
Old 04-29-2010, 07:48 PM
F350-6's Avatar
So do you have an Excursion or a California emissions package truck? Glow plug #6 is the 3rd one back on the driver side. To see if it's actually a glow plug issue, find the long flat connector on the inboard side of the driver side head and unplug it (engine off). Grab a multi meter and set it to read ohms. There will be 9 flat pins inside the connector at the valve cover. Counting from the front, test pin #8 (2nd to last) against a battery ground. A reading of less than 2 ohms means a good glow plug.
If the glow plug reads good, then you've got either a wiring or GPCM issue. If the glow plug tests bad, you've got either a wiring or a glow plug issue. The GPCM is more expensive, but much easier to replace.
MAP vs MAF sensors Bigtruc 1999 - 2003 7.3L Power Stroke Diesel 2 06-24-2012 07:56 PM
MAF sensor code P0102 and NO power at all... AndeyHall 6.0L Power Stroke Diesel 42 07-06-2011 09:32 AM
MAF Sensor TxFireFghter 1978 - 1996 Big Bronco 8 04-01-2010 02:44 AM
7.3 MAF cleaning? Whippled04 1999 - 2003 7.3L Power Stroke Diesel 4 07-23-2007 10:39 PM
where are the IAC AND MAF sensors in a 1996 ranger? fimar7 Ranger & B-Series 1 01-12-2005 06:00 PM
Tags
2000, 2001, 73, air, airflow, broken, diesel, f250, f450, flow, ford, maf, mass, powerstroke, sensor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
