Elec Fan Mounting Advice (1954 F100)
I'm mounting two 12" elec fans to my Alum Rad, I'm not sure of the best medthod of mounting ? Zip ties though the core (zip tie kit furnished with the fans,shown in below pic) or should I build some sort of bracket to mount off the sides of the rad ?
pics below to show what I'm working with.
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=229657&width=0
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=229659&width=2
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=229658&width=2
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
on
Mike
look at my home page 'bout 1/2 way down you'll see a pic of mine... similar alum radiator but with a 16" spall fan. aluminum cross bars that the fan mounts too and the a/c condenser is the same on the other side..
I don't care for the zip tie mounts... kinda cheesy to me
http://jniolon.clubfte.com/
later
John
I have other pics if you need them
later
John
I have mounted the fan to my radiator both ways. When I removed the fan and the zip ties, my brass core was very deformed, tho not leaking.
When I ran a full shroud, the setup worked fine for stop and go traffic, but ran hot on the freeway because my shroud blocked too much ram air.
I vote for a bracket that doesn't block much air, or a shroud with flapper doors that the ram air can blow open so you get the best of both worlds.
I have found that the fan can be 1/4" gap to the core face with minimal loss of efficiency.
Thanks for the advice guys... I like how it turned out..
heres some pics
https://www.ford-trucks.com/user_gal...229732&width=0
https://www.ford-trucks.com/user_gal...229733&width=0
heres some pics
some things have changed a bit in my life since we've talked last.
as far as out of town.. I don't think anytime soon, they have most everything on hold up here now, not much we're able to work on.
