Last edit by: IB Cristina
See related guides and technical advice from our community experts:
- Why Does My Truck Pull One Direction?
Guide to diagnose trouble and recommended solutions
Steering issue after turning
Sure could use some help. I know this one has been beaten to death on this site but I seemed to have missed a most common cause of the issue I am having with my 2005 F250 for the last month. My issue is, sometimes, not always, after making a turn my truck pulls one direction and as I correct it it goes the other way. Does not stop until I either pull over and stop for a few seconds or I jerk the steering wheel back and forth violently. I have read that this can be caused by power steering pumps, brake lines, brake calipers, steering gear, drag link, u joints, front wheel bearings, tie rods, tires and brakes pads. I am sure I have ommitted a few possible causes but I think you get my drift. (pardon the pun). I am not looking for a silver bullet fix but maybe a most common solution to check out. I will post my mistakes and or solutions and hopefully the absolute fix when it happens. Anyone? I have already made a couple of mistakes. Mistake 1, It is not the drag link that was definitely shot. Mistake 2, steering stabilizer. Mistake 3, tires. Mistake 4, power steering fluid. These things I have replaced. All 4 things needed replaced but had no effect on the issue. My truck particulars are 2005 F250, crew cab, 6.0 power stroke, short bed, automatic, 20 inch rims and has 82k miles. Any help will be greatly appreciated.
when my ball joints went out it would make a horrible grinding/rubbing sound when i'd turn.sounds to me like you have steering box issues, especially if you have to shake the wheel back and forth to correct the problem.you could also check the steer shaft, maybe its binding?.my truck's starting to wander, so what youre experiencing is probably in my future.
I did check the steering shaft and did not find any problems. I am going to check it again though. I may have missed something. My problem started subtle at first. A twitch here and there, a strange momentary pull once in awhile and now I can't drive 20 miles without having to stop and let what ever it is correct it's self. I'm leaning towards the steering gear but wish I had a clue that said "Yup that's it". I did try as Cheezit said and go to a repair centers. Actually contacted 3 of them. Each one had a sure fix but 3 different fixes. That's why I'm asking advice on this forum. As common as this issue seems to be there is surely a "Yup that's it".
This may already have been addressed. Replaced Brakes and Rotors, Driver's side sounds like a scraping noise when applying brakes. Locked the hubs on the fly last winter -around 20 mph spinning when it engaged made a huge slamming sound. I should have let the rpm's die down. Could it have caused the ball joint to go bad or did I mess up the locker. It doesn't always make this sound, usually under medium to hard braking and turning. I'm leaning towards either a wheel bearing or a balljoint. Any ideas or advice would be greatly appreciated. 2003 250- 51,000 miles stock. I haven't has any steering issues- pulling, jerking etc. Just the scraping sound almost like a bare pad on a rotor. Thanks for the advice. FTE- The Best! Jamie
