1979 F150 problem
1979 F150 problem
Hi all i own a 1979 f150 4x4... Ive had it about a year now and it has always had a problem starting first thing in the morning... It would start up and as soon as Id throw it in gear it would just die out but after warming up it would be good to go for the day. Figured it was a fuel problem but last week i drove it somewhere, and turned it off.. When I returned to leave the truck would not start and all I hear now is a single click. My lights and radio still come on and I did try to jump it.. Im guessing it has something to do with the starter. Any suggestions?... Im not the most mechanically inclined person.. Might end up bringing it to the shop and paying an arm and a leg for something I could fix for $50.... figured Id give the forums a shot first...
Thanks.
Thanks.
on
Sounds like you're describing 2 different issues...
The dying-out after starting could be a vacuum leak somewhere or the choke isn't working on the carburetor... That would be my guess, anyway...
The other issue could be bad starter, bad starter solenoid, or bad battery. Have you had the battery tested?
I had a 96 F150 that had an issue with the starter. I would turn the key and it would click. It got progressively worse until I replaced it.
Temporary fix was to gentley tap the starter housing with a hammer. The bendix was stuck, so a few taps would get it out of the bind and it would fire right up.
on
If it's clicking, it's probably fine... One of the wires from the solenoid runs down and connects to the starter - it could be that the connection on the starter end is corroded or something and just needs to be cleaned - that can be done easily enough...
The starter is held on with 2 bolts plus the nut for the starter wire - It's an easy thing to pull out and replace. A bit heavy though, so make sure it doesn't fall on your head...
Aaron-71
237
01-24-2018 08:32 AM
redneck4life
05-08-2013 10:18 PM
