HHO Generator - 2007 SD 6.0L
#106
That, ladies and gentlemen, is called "misdirection".
Don't ignore me, address those key issues. Right now, it sits like this in a room:
You are apparently incapable of the same. Makes me wonder what is really driving you on your quest? By the way, I will ”Own my position proudly”. My mama taught me there would be people like you. I wouldn’t waste my time showing you anything, you’d just ignore the data and call me a liar if it countered your position.
Don't believe me? Please quote in this thread where someone has posted FACTS that support HHO works in our vehicles. If you really "own your position proudly", then you would be able to support your position and prove it. So far, you haven't.
#107
You need to build a dry cell out of 316l stainless. check out this link HHO Connection Resources - Videos, FAQs & Links
This is taken directly off the home page under FAQs:
HHO as a fuel supplement for vehicles
The average internal combustion engine burns about 30% of its fuel at best. The rest is wasted and left behind in the form of carbon deposits in the engine, or it goes out of the exhaust and into our air as carbon emissions. Adding HHO helps to burn the fuel more efficiently, resulting in almost 100% of the fuel actually being burned. If applied properly the benefits are increased power and cleaner emissions. And, since the fuel is being burned more efficiently, less is needed, resulting in better mileage.
See HHO folks. If someone knows anything about engines, it's VERY easy to spot the lies from scammers. What's funny is the HHO fan club won't even try to argue against me, because they can't.
#108
You needn't invent the thing to be a consultant.
As to why the people SELLING the scam equipment aren't raking in tens of millions of dollars from OEM sales, I'll let them answer why that isn't happening.
This is what big boy hydrogen generation equipment looks like. Teledyne (stock symbol TDY) has been in the tech game for a very long time, so why aren't THEY selling HHO kits or OEM vehicle systems? With their money, there is no barrier to market entry.
http://www1.eere.energy.gov/hydrogen...q=electrolysis
#109
[quote=monckywrench;10502370]That isn't even on-topic. If you have a system with that cell you can PROVE works, then prove it. You can use that proof to hunt venture capital and Green energy research grants.
Have you wasted your time building an HHO system?
#110
More BS.
What's funny is I already addressed this earlier in the thread. It is a common mis-conception perpetrated by HHO scammers. Again, modern internal combustion engines burn nearly 100% of the fuel, not 30%. They try to equate the amount of fuel burned with "thermal efficiency". The two are not one and the same.
Oh, by the way, have you tried HHO?
#111
Why do you think detroit put computers in the cars, nothing simple there.
Computer control in many ways does simplify control systems for the engineers although the computer is modestly "complex".
Computers allow granular control and monitoring of temperature, pressure, rpm, vehicle speed, fuel flow, and any other parameters the designer wishes. That allows inferring load and adjusting power accordingly. Throttle inputs become a "request" which the system meets within its parameters.
Making power IS just "burning fuel", with precise process control being a design object.
Computers make DIY tuning practical, so when you prove HHO works it will be easy to add to computer controlled systems.
Here's some info to roll your own on your way to HHO wealth. A modded or replacement ECU with appropriate controls could give you control with real time monitoring over every aspect of HHO production and use.
Welcome to diy_efi/efi332
#112
And HHO absolutely, totally, 100% CANNOT change thermal efficiency. Period. End of discussion. You have no argument against it either. You cannot introduce a magical gas it the intake stream that will force the block and cooling system to take in less heat.
I know the laws of physics. So why on earth would I waste my time.
By the way, I played around with electrolysis in high school. We did that in our chemistry class when learning about polar covalent bonding. You may want to look up that term. Once you figure out what it means, you'll quickly understand why HHO doesn't work.
Now, do you actually have anything relevant to discuss, or do you plan to post responses that continuously dodge the topic, and clearly make zero sense.
#113
This part makes zero sense. Seriously. Your reply has zero logic to it. I already explained the differences between percentage of fuel burned and thermal efficiency. No, not all fuel burned makes mechanical work. I have ALREADY STATED THAT. Which is exactly why your post makes zero sense.
Check this out Genius, unless he's lying to SAE.
Or maybe you're better than Society of Automotive Engineers. I'll make it easy for you: 2004-01-0972
Here, I'll even give you the abstract.
Influence of Hydrogen-Rich-Gas Addition on Combustion, Pollutant Formation and Efficiency of An Ic-SI Engine
Document Number: 2004-01-0972
Date Published: March 2004
Author(s):
Enrico Conte - ETH Swiss Federal Inst. of Technology Zurich
Konstantinos Boulouchos - ETH Swiss Federal Inst. of Technology Zurich
Abstract:
The addition of hydrogen-rich gas to gasoline in an Internal Combustion Engine seems to be particularly suitable to arrive at a near-zero emission Otto engine, which would be able to easily meet the most stringent regulations.
In order to simulate the output of an on-board reformer that partially oxidizes gasoline, providing the hydrogen-rich gas, a bottled gas has been used.
Detailed results of our measurements are here shown, such as fuel consumption, engine efficiency, exhaust emissions, analysis of the heat release rates and combustion duration, for both pure gasoline and blends with reformer gas. Additionally simulations have been performed to better understand the engine behavior and NOx formation.
Results show that: When running at \gl=1 and without EGR, addition of hydrogen-rich gas produces a significant shortening of the very first phase of combustion (inflammation phase) rather than of the remaining combustion process; Addition of hydrogen-rich gas allows to run the engine at extremely high \gl or EGR rate; When running at the highest possible \gl or EGR (limited by COV increase) the duration of all phases of combustion remains almost unaffected by the diluents; In all conditions a significant decrease of UHC and NOx emissions has been observed; In all conditions a significant increase of engine efficiency has been measured, which seems to be enough to compensate and overcome the losses due to the partial oxidation of Gasoline in the Reformer. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
#114
First, that shows absolutely nothing. I'm not paying $22 to read it. You gave us nothing but an abstract of a paper.
Even with the abstract, here's a part that you seemed to have glossed over:
See that? They didn't even use an HHO generator for the test. They used bottled gas. Meaning they had a large enough quantity from an outside source, not an onboard generator powered by the engine itself.
That little sentence peaked my curiosity, so I searched and I did find a bit more info on that test: http://www.lav.ethz.ch/research/projects/Flyer-EC.pdf
First, the bottled gas they used was a "blend of CO, H2, and N2 (24%, 21%, 55% by volume)". Ladies and gentlemen, this is NOT HHO. HHO is hydrogen and oxygen, not CO, H2, and N2. Right there we have debunked Marianna. But wait! There's more!
Second, the engine used was a "Lombardini 4-stroke, 2-cylinder, 0.5-liter engine" that was modified extensively and exclusively for the test. This is a far smaller engine than what anyone drives on the street, and far smaller than the 7.3L diesel that Pappy2 boasted as getting "36 to 38+ mpg". And yet again I'm going to repeat this... it was NOT an HHO kit, it was gas introduced from a BOTTLE, an OUTSIDE SOURCE, on a VERY TINY ENGINE.
Third, if you look at that link, they ran the test from 100% gasoline all the way to 100% gas from the bottle. This is IMPOSSIBLE TO DO with an HHO kit because it does not generate the volume needed.
Basically they came up with a gas combination to replace regular unleaded gasoline, and were able to introduce enough of it to completely cut off the gasoline supply and run the engine. Yet again, this is NOT an HHO kit. It's NOT HHO gas. It's NOT an onboard HHO generator.
Hell, the same can be accomplished with propane. Anyone can covert a gasoline engine to run on propane. That technology has existed for decades, and a handful of people actually do it. It's simply a principle of finding a replaceable fuel with enough flammability, BTU's, and volume to replace gasoline, then tweak the engine fueling and timing to make use of it.
That was a pitiful attempt to try and pawn off this test (actually just the abstract) as so-called proof that HHO kits work. What's sad is this very same abstract appears on many HHO scam sites, and is quoted as being so-called proof that HHO works. It's not even a test of HHO generators to begin with, yet it's touted as such because these scammers post nothing but the abstract as a vain attempt to pretend HHO generators are legit.
Marianna, you've just been owned. We asked for proof, you provided NOTHING.
#115
I did a lot of testing on my old truck, there was a little success, but not 38 mpg.
I didn't notice any difference in exhaust smell, and at really high concentrations it smoked like hell.
I noticed at night that when the HHO was running that the exhaust had no haze from a flashlight, and did without HHO. I replicated that several times.
My theory is that the hho is helping the fuel burn a touch quicker, easily done with a tuner.
MPG gains were small, it is very hard to calculate without a lab.
#116
A pseudo-simulation of a mythical product by a totally different product is junk science.
Not that the pseudo-science advocates are even capable of understanding "one thing is not like the other".
That's like saying "my F150 simulates a perpetual motion powered vehicle because it has four wheels".
#117
In all seriousness, with my testing, even if the system worked, the gains would be too small to **** around with a circus of wires and hoses. I didn't even bother with it after a while cause it was winter, and it wasn't worth the hassle.
Now, if you could harness electricity while slowing the vehicle at a stop light, then burn the HHO at take-off, you'd have something.
#118
You could in fact make something like that; it's called regenerative braking, and it's what the hybrid vehicles do. Now retrofitting it onto a truck might be challenging, to say the least.
#119
I have also been playing around with an HHO setup in my 03 6.0 F250 .I have a pro series HHO system with a 30amp pwm using sodium hydroxide, To save people time I do not sell or advocate anything to do with this subject, I am just experimenting with different alternative fuel sources. I am a find out for myself person, I have my own fabrication buiseness and a certified by FMC up to 2010 Auto @ Diesel Master tech when I left to do my own thing. I have not seen any real gains using the HHO system except when driving on the freeway at speed about 70 to 75mph I noticed that the throttle position is about 20% percent less than without HHO, Used my matco scanner to moniter the pids while driving. I dont know what that amounts to in fuel savings but I have seen it myself that it does do something. I also designed my own propane injection system (not for sale) Using a variable regulator working off the trucks eng boost pressure and input from the tps, Talk about a kick in the ***, definate improvement in power and fuel economy. The power increase is identical if not more than a 100hp programmer ive tried and the fuel economy I dont know the exact numbers except i used to use a tank of fuel a week and with the same amount of drivng i am getting almost 2 weeks of driving now. The biggest issue is the exhaust stinks bad and getting the regulators set so the engine didnt lean out to much or load up at low input but now it is working great and i am still running the HHO system with the propane injection. Does this rate my truck as a" Hybrid "LOL.
#120
I'm no chemist, but I don't believe the theory contradicts the laws of thermodynamics, as the system is designed to reduce the waste of incompletely burned fuel, not add a source of energy. That being said, is there anyone that has successfully tried this? Ya know, that isn't selling it? I have no problem trying it myself....
