not sure if i need to replace fuse box or gem module - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-27-2010, 12:12 AM
jclape jclape is offline
jclape is starting off with a positive reputation.
ok i know that the winshield leaked into the fuse box and the Theft/Locking MODULE i actually had to drain it there was so much water in it . all the doors lock but only the drivers door unlocks and the drivers window and the rear passanger window both dont go down. when the leak caused all the issues the window was still working up and down but only if the radio shut off on its own then other items worked when it all dried out i took the fuse box out and spayed it with pb blaster to dry it out and looked at the gem it looked good no corrosion that i could see. any clue why doors lock but dont unlock and window issues. its to expensive to replace all of it gem and fuse box even used i cant find the right year fuse box used and gem would have to be programed
Old 04-27-2010, 01:18 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
There is several posts regarding this. One for sure includes a detailed pictorial on cleaning the fuse box and maybe the gem module, do a thorough search, you should be able to find it.
Old 04-27-2010, 01:38 PM
i have looked over the past3 days here and different forums an found lots of the same issues with no answers that have worked
Old 06-23-2010, 10:26 PM
03BLKEB 03BLKEB is offline
03BLKEB is starting off with a positive reputation.
I searched for cleaning the fuse box / gem with no luck finding the post with pics, anyone else searching differently and have luck?
Thank you
Old 06-24-2010, 12:38 AM
Moto Mel's Avatar
Quote:
Thank you
Send a PM to alloro, he seems to be the resident historian of this forum. I've read the posts but now I can't find them either.
Old 06-24-2010, 02:11 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Hey, you said it so you do the research and then back it up with the link! Besides, I already looked and couldn't find it either, nor do I remember ever seeing it.
BTW, I have PMs turned off.
Old 06-24-2010, 01:15 PM
Moto Mel's Avatar
I may have seen this issue and it's fix on the F 150 or Excursion forum. I have a tendancy to wander around a bit. I'll try to look there later. I have to attend to some "Honey Do" stuff for a while today.
Old 06-25-2010, 01:13 PM
Moto Mel's Avatar
Here's the link to the info I was mentioning. Pay close attention to post #9.
http://www.ford-trucks.com/forums/87...l?nojs=1#links
Let us know your results.
Old 06-28-2013, 08:50 AM
Hooie2013 Hooie2013 is offline
Hooie2013 is starting off with a positive reputation.
So how did it work out for you?
Old 08-29-2013, 06:28 PM
CHIEFSOU's Avatar
CHIEFSOU CHIEFSOU is offline
CHIEFSOU is starting off with a positive reputation.
I had similar issues removed Gem cleaned circuit board and resoldered many resistors that had poor solder and fixed it myself for free. everything works great now.
Old 08-30-2013, 09:08 AM
Quote:
Interesting...I think you're the first person to post about cold solder joints being the cause of GEM issues. I'll have to keep that in mind as a possible solution in the future.
Rep points to you!
Old 08-30-2013, 11:19 AM
CHIEFSOU's Avatar
Yep FORD is notorious for using large flat surface mount resistors that build heat and they always come loose, fixed many overhead displays for compass/gas monitor modules same problem, in the EXPY also fixed odometer light being out same type of issue resolder pins and resistors now it works perfect, all these boards are soldered by machines and fail over time, 99.9% of the time re soldering will fix most issues or leaky capacitors in any other case depends on age of vehicle and Electrical problem this holds true with anything electronic caps or poor solder repairs save you hundreds of dollars on all types of electronics.
Old 09-02-2013, 08:30 AM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
I have a 98 and have the same issues found my problem this weekend when I started doing body work. My rockers are all rotten so I removed my running boards and started cutting out the rotten rockers I then noticed a hole in the floor on the drivers side I took all the plastic kick panels out on the drivers side inside to find a wiring block of some kind (I have no Idea what it is called)that had been exposed to the elements for some time and it is all green the parking brake cable also comes through the floor here I am figuring that is my problem .
Hope this helps wiring gremlins suck.
Old 07-20-2014, 12:29 PM
taz1974 taz1974 is offline
taz1974 is starting off with a positive reputation.
Hello, I am looking for some information about the fuse box/GEM moduel. I have a 2003 ford f150 and know that there is water damage to these componets. I have several questions however. 1. if I can clean the original fuse box/gem module, does the truck still have to be reprogrammed after it is replaced. if so, can it be driven to do so? 2. if i have to go new instead of cleaning them i know it will have to be programmed. however, can it be driven as well to have it taken to a shop.
If it can not be driven without being reprogrammed it kinda defeats the purpose of doing it yourself. Thanks for your help. I have been able to find out a lot bout this matter.
Old 07-20-2014, 02:35 PM
1. No.
2. No.
Battery Drain Issue - No Dome Lights, No Power Windows gkotlin Excursion - King of SUVs 1 01-01-2017 07:33 PM
GEM module failure ? Jason Lilly Modular V10 (6.8l) 0 01-19-2016 11:02 AM
Help - H2O = no go! rflegal Excursion - King of SUVs 12 06-20-2015 12:55 PM
99 F250 GEM Issue Zazoos 1999 to 2016 Super Duty 0 10-11-2014 08:12 PM
gem mod and fuse box jclape Expedition & Navigator 8 04-21-2010 08:29 PM
Tags
1997, 2001, 98, excursion, expedition, f150, ford, fuse, fusebox, gem, lincoln, module, navigator, panel, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
