8 lug rims
8 lug rims
hi guys im looking for 8 lug rims for my trailer, it has dexter axles on it, that use the ford rims. i need a 4 INCH offset for the rim to fit correctly. but my question is, is thier a "standard" for the ford 8 lug rims? like say.. they are all 5 inch offset?? or maybee the van rims are different? hanks in advance
Hi tennykimble. Welcome to FTE.
Offsets on the rim (or backspacing) varies depending on what year truck you are looking at.
2004 and older Super Duty trucks had a leaf spring front suspension which required the wheel to be moved away from the truck. 2005+ trucks have a coil spring front suspension, which required the wheel to be moved more towards the truck.
I can't say if the vans are the same.
spkennyva
12-11-2011 11:10 AM
1992FordF150Custom
10-07-2011 03:22 AM
