Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-26-2010, 09:22 PM
gb'sfx4's Avatar
gb'sfx4 gb'sfx4 is offline
old enough to know better
Garage is empty, add now
gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.gb'sfx4 has a great reputation on FTE.
adding bio to diesel
I want to start adding b50 or 100 to a full tank of #2.
will the bio blend with the diesel if I just dump it in at fill up or is there a better way of mixing it?
__________________
(early) 03 F-250 6.0 CCLB FX4, arp's, not tuned, 4"mbrp, cat/muff delete, edge insight w/pyro, bulletproof egr, high idle, zoodad,onboard air, rear bags, B&W gooseneck hitch, pro comp 2.5" level kit,1500w inverter, 10"dvd, back up camera, 150,000 miles
  #2 (permalink)
Old 04-27-2010, 12:15 AM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Just dump it in. It'll mix just fine.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #3 (permalink)
Old 04-27-2010, 11:19 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Making your own? Come winter you may need to do that anyway, depending how cold it gets... I am at about 70% bio now, still getting down into the 30's.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #4 (permalink)
Old 04-27-2010, 03:25 PM
gb'sfx4's Avatar
Buying not making. Just using it for it's lubricating properties in my 6.0, how many tankfuls before changing fuel filters - say if I run a B5 blend ?
__________________
  #5 (permalink)
Old 04-27-2010, 04:07 PM
TurnerBioDiesel's Avatar
TurnerBioDiesel TurnerBioDiesel is offline
2003 Ford Excursion
TurnerBioDiesel is starting off with a positive reputation.
Quote:
In my 6.0 i have been doing it on the second oil change. So about every 6-8 thousand miles. That may be a little much but I really have way to much money in it to have somthing go wrong from a bad filter. You should be good with normal change intervals with b5 blend. If you notice loose of power i would change imediatly. Pluged filters and or not enough fuel pressure will kill every injector with no murcie.
  #6 (permalink)
Old 04-27-2010, 05:46 PM
gb'sfx4's Avatar
been there & done that ... really need to avoid injector failure .... that's why I'm asking
thanks again
__________________
  #7 (permalink)
Old 04-28-2010, 01:50 AM
peruses peruses is offline
peruses is starting off with a positive reputation.
glad I run an idi just carry spare filter and change it when she starts to surge, if it ever hurts an injector whole set is $200
__________________
I have more obsesions than I care to count; thats cause I'm not obsessed with counting my obsesions.
87 F250 diesel with 89 7.3 and banks turbo
and a few smaller diesel motors
  #8 (permalink)
Old 04-28-2010, 09:38 AM
gb'sfx4's Avatar
WOW - 200 won't even get me one injector
__________________
  #9 (permalink)
Old 04-29-2010, 08:44 PM
Rushmore X's Avatar
2003 Ford Excursion
Funny, this just happened to me this trip. Changed the filter and ran like new again. About 15000 miles on the filter, I was going to change it after i came home...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
