Isspro EV2 Install - Ford Truck Enthusiasts Forums
Isspro EV2 Install
Old 04-26-2010, 04:01 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
Isspro EV2 Install
I'm in the process of installing a set (pryo/boost/tranny) of EV2's in my truck and have a wiring question. The kit have bought has the dimmer pot, aka potentiometer. The wires off the dimmer switch don't match the instructions: The instructions show 6 wires coming off the switch,
1. Short Black (goes to ground)
2. Short Orange w/Black tracer (goes to headlight dimmer)
3. Short Red (goes to 12v power keyed source)
4. Long Black (goes to gauges/ground)
5. Long Orange (goes to gauges/dimmer)
6. Long Red (goes to gauges power)
My switch does not have the red wires, but the kit did come with a long red wire zip tied, but not attached to, the switch.
I'm thinking I can just run the red wire from the fuse box directly to the gauges daisy chain style?
Anyone else have one of these installed? I've emailed MichaelP & David Murphy but have not heard back yet...
Thanks!
Old 04-26-2010, 05:12 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
run the long red wire that's all by itself as the power daisy chained. Run the red wire from fuse number 4(warning buzzer, instrument illumination, etc..) and daisy chain it up the guages. run the orange wire w/ the black tracer from the Pot. to the number 10 fuse(instrument illumination). running those like that will allow you to use the pot to set the maximum brightness of the guages, then use your factory dimmer switch to dim the EV2's with the factory dash guages.
Old 04-26-2010, 07:12 PM
BadDogPSD's Avatar
Got it, thanks Travis!
Old 04-26-2010, 07:15 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Yea, if you buy isspro's without the dimmer, you have to get your own power wire.
Not sure why they do that, but thats how it works. The directions are a bit confusing, but they make sense after you stare at them for an hour.
Old 04-26-2010, 07:20 PM
BadDogPSD's Avatar
Quote:
or two, or three... wiring is NOT my thing!
Old 04-27-2010, 06:26 AM
did you get them hooked up ok????
Old 04-27-2010, 08:13 PM
BadDogPSD's Avatar
Quote:
I think so... batteries are getting weak and it wouldn't start
It's on the charger and I'll try again in the morning!
Thanks again for all the help.
Old 04-27-2010, 11:01 PM
did the lighting work on them? with mine when you turn the key "on" the guages reset and come back up. don't need to start it to make sure the lighting works and they are reseting. the boost guage doesn't drop obviously b/c it's always on zero, but the EGT does.
Old 04-27-2010, 11:07 PM
Talyn's Avatar
my boost drops below zero to the peg and then goes to zero.
Old 04-27-2010, 11:12 PM
my peg is the zero on mine. haha. strange that yours isn't... i will have to double check mine now. i never look at boost anymore. always look at EGT, ICP, and oil temp. haha. might be b/c the boost guage is the top guage on my 3 guage pillar..
Old 04-27-2010, 11:15 PM
Talyn's Avatar
I am honestly tempted to pull the boost and put my scan gauge in there for now.
If i want boost, i can just select it on my scan gauge.
I run coolant, EGT and oil temp. I rarely look at the boost gauge too.
Need to keep an eye on that EGT gauge for me though, I was pushing 1300 the other night following katie.
I was like. WTF, no smoke? and then looked and saw 1300. I was like. Oh..... Right.
Old 04-27-2010, 11:42 PM
i wish i could say i only see 1300*.... if i get on it decent in my big tune i see 1600 by the time i get to around 80mph... after a full pass down the drag strip it takes a second or 2 for the needle to come off of the peg. probably shoulda gotten a 2000* pyro.. haha
Old 04-28-2010, 07:55 AM
Talyn's Avatar
I want stage 2s now too.
I love my Isspro's they work good and look good.
I want them to make an analog clock that looks like the gauges, so I got some old style clock like the old cars do.
Old 04-28-2010, 01:26 PM
BadDogPSD's Avatar
Success! Got them working. They don't sweep when I turn the key on, but took a quick spin and the egt's & boost looked they they were doing their thing. The tranny temp didn't move, but it's cold outside and I didn't drive very long...
I'm going to send a note to Isspro with some suggested changes to their
wiring instructions!
Old 04-28-2010, 06:20 PM
i was tempted to send them an email on their instructions, but after i read them the 2nd time i completely understood what needed to be done so i didn't do it. get a little more drive time to make sure the tranny temp is working, but great job getting them working!!!
Gauge Illumination/Dimmer Switch 2_Tone 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-18-2016 12:37 PM
Radio Wiring Help (retrosound) TheCoach 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-11-2015 12:31 PM
Isspro EV2 light flickering 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 04-20-2013 05:31 PM
Dim Gauge Lights yobuda Electrical Systems/Wiring 2 07-06-2004 09:06 PM
87 F150 No Low Beams opjgeorge Electrical Systems/Wiring 6 10-29-2002 01:48 AM
Tags
73l, boost, clock, dimmer, ev2, gauge, gauges, harness, install, insterll, instructions, isspro, lighting, night, potentiometer, view, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
