Isspro EV2 Install - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Isspro EV2 Install
Old 08-05-2013, 11:52 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by strokin'_tatsch View Post
run the long red wire that's all by itself as the power daisy chained. Run the red wire from fuse number 4(warning buzzer, instrument illumination, etc..) and daisy chain it up the guages. run the orange wire w/ the black tracer from the Pot. to the number 10 fuse(instrument illumination). running those like that will allow you to use the pot to set the maximum brightness of the guages, then use your factory dimmer switch to dim the EV2's with the factory dash guages.
How do I join the wire to the fuse?
fuse #10 and 4, Does each fuse have a numerical slot? OR are you referencing to fuse with a 4 and 10 on it. Because there are 2 fuses with a 10 on them.
Old 08-06-2013, 11:02 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
When I installed my EV2's I tapped into the back side of the fuse box for the dimmer and for the power. My gauges dim with the factory gauges and I see no need for the optional Isspro dimmer from my experience. YMMV.
Old 08-06-2013, 11:29 AM
mjunk1's Avatar
mjunk1 mjunk1 is offline
mjunk1 is gaining momentum as a positive member of FTE.mjunk1 is gaining momentum as a positive member of FTE.
They make a fake fuse that you can run your wire into and then plug into the slot. I think they make one that kind of slides in with existing fuses in place too. Your basic parts store will have them.
Old 08-06-2013, 01:51 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
Yup... It's called a fuse tap.. It slides over the blade of the fuse, re-install the fuse and it has a blade sticking out by the fuse for you to connect a spade end wire terminal to. By number 4 and 10 fuses I mean the number of the fuse in the interior fuse block. The fuse block cover has the numbers on it and what each fuse is for.
Old 08-07-2013, 12:04 AM
Thank you so much guys, my gauges are gauging!!!
Even though i was driving at night and they started to flicker a couple times, maybe a loose illumination wire?
Old 08-08-2013, 11:59 AM
Loose illumination, power, ground, or they aren't set bright enough. When you dim the LEDs down too much they will start to flicker.
Just the lights flashing or were the gauges turning off and on?
Old 08-08-2013, 01:38 PM
The gauges still had power.
I think you hit it right on the money, w them being on too low of a brightness.
All wires seemes like good connections.
Ill take her for a spin tonight
Old 02-11-2014, 06:12 PM
PAN's Avatar
PAN PAN is offline
PAN is starting off with a positive reputation.
#4 isn't a 12v keyed power ignition source though... Its always on or hot on my 94 F350. Are the 95-97 trucks different ?
Gauge Illumination/Dimmer Switch 2_Tone 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-18-2016 01:37 PM
Isspro fuel pressure gauge issues Ktm350 1999 - 2003 7.3L Power Stroke Diesel 7 02-08-2015 09:50 PM
Radio Wiring Help (retrosound) TheCoach 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-11-2015 01:31 PM
Isspro EV2 light flickering 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 04-20-2013 06:31 PM
ISSPRO Performax Gauge Install PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 60 04-09-2011 10:17 PM
Tags
73l, boost, clock, dimmer, ev2, gauge, gauges, harness, install, insterll, instructions, isspro, lighting, night, potentiometer, view, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
