Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-26-2010, 01:52 PM
Jrakar Jrakar is offline
Garage is empty, add now
Jrakar is starting off with a positive reputation.
Stupid 4x4 question
Looking at a used 2009 Expedition El with 20k miles. Took it for a test ride and put it in 4x4 high and turning a corner it started to feel like the transmission going fall out from under the truck. Lots of thumping and clunking. The dealer told me yes it will do that on dry pavement in 4x4. Is this true?
  #2 (permalink)
Old 04-26-2010, 02:15 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
4x4 Hi / Lo will make said noises
4 Auto should not make those noises
  #3 (permalink)
Old 04-26-2010, 04:28 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Driving 4x4 on dry pavement and turning=NO NO.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 04-26-2010, 05:20 PM
ford12508 ford12508 is offline
ford12508 is starting off with a positive reputation.
Pretty much what you did to that truck should never be done to a vehicle. In 4x4, the wheels have to turn the same amount, so while turning, the inside wheel doesn't have to turn as much as the outside wheel, thus the axle will start to twist as the traveling distance grows further apart.
The reason you can turn on mud/snow/ice/gravel is that the tires are not glued to the surface and can turn more freely, so if the axle starts to twist, it can give off enough power to the wheels to make them break free of the surface and spin.
Edit-Now I feel like a jackass, because I did not realize until just now that the new expeditions don't even have solid axles, they have control arms. I do not know how turning in 4x4 on dry pavement works with control arms, but just don't do it haha
__________________
Brian
1999 Ford Expy 5.4L
Pioneer 4-way speakers, Ignition Ding turned off, Rubberized undercoating in process
  #5 (permalink)
Old 04-26-2010, 07:24 PM
n2umr n2umr is offline
n2umr is gaining momentum as a positive member of FTE.
If I were the dealer and found out that you did that I would have made you buy it. Anyone who knows anything about 4x4 would never ever put a vehicle into 4 wheel drive on pavement, you could have and may have hurt that truck.
Mark
  #6 (permalink)
Old 04-26-2010, 09:20 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
It's called axle windup. When it gets too tight the tires slip -- bang! -- hopefully just the tires. 4x4 is only good on loose surfaces or snow, never dry pavement. 4x4 Auto is a different animal and even that is rarely needed.
-- Chuck
  #7 (permalink)
Old 04-28-2010, 12:22 PM
gr8dain's Avatar
gr8dain gr8dain is offline
gr8dain is starting off with a positive reputation.
You just test that the 4x4 system was working. I did that to all of the Jeep wranglers I test drove before buying them. I just did it enough to feel the initial hop to make sure the wheels engaged. I did not want to tear up anyone's vehicles. Of course I did find a few that never engaged, so I was glad I did the test.
BVut I do agree, 4x4 on dry pavement is a bad thing.
Dain
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
