2002 Explorer auto 4wd mode - Ford Truck Enthusiasts Forums
Old 01-29-2003, 11:29 PM
silcom silcom is offline
silcom is starting off with a positive reputation.
Have a 2002 4.6L 4x4 Explorer. My understanding is that in auto mode it will sample wheel slip and "seamlessly" engage the front axle. Well, it feels as if the engine is missing when it starts to slip and tries to power the front end. It's sort of like it samples the slip about 5 times a second and you feel every one. Basically, it is not seamless, it's distracting. I know it's not the engine because as soon as I press the 4x4 button the "miss" quits. Is this normal or is this warranty time?
Old 01-30-2003, 07:07 PM
N700MS N700MS is offline
N700MS is starting off with a positive reputation.
Well I don't have a 4x4 but I would say its normal since the front axle would have to catch up to the rear one. But Ford does say it should be smooth engaging so maybe you should have it check out.
Old 01-31-2003, 04:56 PM
DVigeant DVigeant is offline
DVigeant is starting off with a positive reputation.
I have the same vehicle. I've "gunned" it a little in the snow and the rear tires spun for a split second and then it gripped with all fours and accellerated pretty good. No complaints on my end. Maybe there is a legit problem with yours. Have it checked out, it's free.
Old 01-31-2003, 06:50 PM
tonga3 tonga3 is offline
tonga3 is starting off with a positive reputation.
I had a 2000 4.0l and when it was in auto if I caught some snow it would definately thump in and out of 4wd, as it caught traction it would disengage and then it would slip again and re-engage, apparently this is normal. I drove mine for 100k and never encountered any problems with it.
Old 01-31-2003, 07:38 PM
1956MarkII 1956MarkII is offline
1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.
Does your vehicle have any form of traction control? That could cause the engine to retard (to reduce wheel spin), creating the situation you're describing. If you do have traction control, try turning it off to see if the problem goes away.
Old 02-04-2003, 03:02 PM
coop999 coop999 is offline
coop999 is starting off with a positive reputation.
Arrow 2002 Explorer auto 4wd mode
Our 2002 Explorer has the same jerking action (I think that it is kicking in and out of 4wd) when travelling at slow speeds or starting out, but if you accelerate more it seems to stay in 4wd.
I normally select the '4wd high' if I am driving slowly in slick conditions to head-off any damage that this jerking may cause to my drivetrain. It definitely doesn't seem 'seemless'.
My wife only has 46,000 miles on it so far, but I hope she can get at least 100,000 more before she is ready for another one.
Old 02-08-2003, 09:34 AM
Taffy.C Taffy.C is offline
Taffy.C is starting off with a positive reputation.
My 2003 explorer 4x4 does exactly the same thing. The first time 4wd engaged was on some snow and I wondered what the heck the big jolt was. Seems to be only at low speeds I get the jolt. At > 20 mph its prety smooth, but still very different to what I was expecting - I think Ford could be a bit more up-front that its not "like AWD".
Old 02-08-2003, 06:53 PM
mgazak's Avatar
mgazak mgazak is offline
mgazak is starting off with a positive reputation.
I've never driven an 02+, but I can you that I experience the same thing in my 98. Overall, the system works well, though.
Old 02-09-2003, 03:48 PM
Thanks for the posts. Appears this is normal, although I'll probably have the dealer check it under warranty, now I have more info to go on.
Silcom
Old 02-10-2003, 12:47 PM
Hey guys,
I posted earlier and stated that I too had a '02 XLT V8 Auto, and I don't have any of the mentioned problems with the 4x4Auto. Well, it snowed pretty good the other day and I really got a chance to test it again. I can say with a good degree of certanty that I don't have the problems mentioned. I stomped on that thing dozens of times, in soft snow, packed snow, slush, etc... no issues. The only time it made a jolt/noise was when my rear tires were in snow and my fronts were on the pavement. I think that's to be expected though. Hope my input helps.
2002 Explorer....4WD questions from down under Newlo Explorer, Sport Trac, Mountaineer & Aviator 5 05-10-2013 03:24 AM
2013 dislikes-Transmission, dome light, floor vents, dipstick 3speed 2009 - 2014 F150 41 05-02-2013 05:38 PM
97 Explorer - 4x4 not working. rlester Explorer, Sport Trac, Mountaineer & Aviator 2 04-12-2013 10:31 PM
Out of the PSD, in a F150 Ecoboost spdmpo 1999 - 2003 7.3L Power Stroke Diesel 31 04-06-2011 07:17 PM
Suspension Mod RBRADBURY9753 Excursion - King of SUVs 18 06-30-2010 09:46 AM
Tags
2002, awd, explorer, ford, jerking, slipping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
