why do head gaskets block water ports on 302 - Ford Truck Enthusiasts Forums
Old 04-25-2010, 11:59 AM
1bad67sbf's Avatar
1bad67sbf 1bad67sbf is offline
1bad67sbf is starting off with a positive reputation.
i just put my e street heads on and noticed that the fel pro gaskets only have the rear water jackets open. is this to force water thru the smaller ports near the cylinders
Old 04-25-2010, 11:28 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
I`m pretty sure you need to trim any of the gasket material that would restrict the flow of water to the heads.The gaskets can be used on different heads with a different port shape. It should mention that in the instructions.The blue sealent ridge should outline the ports. Thats if I`m following what your saying.
Old 04-26-2010, 07:16 AM
1bad67sbf's Avatar
you do trim them for the intake gasket but not the head gasket unless your running a 351w i think
Head gasket question skidoorulz 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-31-2015 04:29 PM
Upsidedown Headgasket? fsvahn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-26-2012 09:10 PM
Marine ford 460 intake manifold gaskets michbol 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-14-2011 02:25 PM
400 Headgasket confusion cyrrius 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-03-2011 01:33 PM
intake manifold water ports missing? Pond Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 07-13-2004 08:37 AM
Tags
1967, 302, f100, fel, ford, gaskets, head, intake, outline, ports, pro, put, rear, trucks, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
