Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-25-2010, 07:49 AM
gaffer222 gaffer222 is offline
Garage is empty, add now
gaffer222 is starting off with a positive reputation.
2007 Expy Limited VR3 Backup Camera Install
Just joined the forum. We purchased an 07 Expy Limited 2 weeks ago with 33K miles. It's loaded but no Backup Camera. I purchase a wireless VR3 at Wally World on clearance for $74.
I want to hard wire the monitor to a switched 12 volt source. I was thinking about the Brake Controller Harness(not sure if that is switched). I also see a harness connector behind the radio plate that's not hooked to anything. I have not taken it apart yet and tested for voltage but it looks like a flat 4 slot connector.
I also have read that the center terminal in the 7 pin trailer harness is reverse lights on the Fords(need to confirm this also). If so I think I will mount the camera directly on top of the hitch receiver, not on the license plate. This will save running the wires up throught the hitch gate and back down the rear pillar to the reverse lights.
I'm going to install my Prodigy Brake controller and the 12volt charge relay/ fuse today and then look at the Camera install. It's raining here today so it's a good day for this work in the garage.
Anyone have experience or suggestions to share.
Thanks
  #2 (permalink)
Old 04-25-2010, 01:28 PM
hookd's Avatar
hookd hookd is offline
2009 Ford F-150 SuperCrew
hookd is starting off with a positive reputation.
I have been thinking of adding one but have not looked to far into it yet let us know how it works out and some pics would be great. I like the idea of not wiring through the lift gate that will be interesting to see how it works. good luck
__________________
HOOK
09 F150 SCREW 5.4 4x4 I finally got my dream truck
10 Dodge Caravan (I know its a minivan 4 kids don't fit in anything else that can get 25 mpg on the highway)
  #3 (permalink)
Old 04-25-2010, 01:34 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
I'm keeping my eye on this one too. We have an '07 Navi EL with Nav. I think I'm going to do a separate screen and mount it just above the rear view mirror.
Not sure if yours is wireless (from the front to back) but I'm inclined to run wires for better resolution and less interference. Seems like some of the screens have to be turned on every time you start the vehicle, but I want mine to come on automatically whenever reverse is engaged.
I'm intrigued by your trailer hitch mount idea but I wonder if it will give you the proper perspective on what's immediatly behind the vehicle?
Interesting idea to tap into the trailer harness.
Good luck!
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #4 (permalink)
Old 04-25-2010, 04:29 PM
The Backup camera and the Brake Controller are installed. I did wire the camera to the center lug of the 7 pin trailer harness as this only powered when in reverse. I connected to the center wire behind the 7 pin connector. I'm not totally happy so far with the camera location and still may move it. I double side taped it to the bumper just above the hitch receiver. I want to be able to get a good view of the hitch ball so I can connect the camper as well as use it for backing up without the camper. The view is good but the camera sticks out like a sore thumb. It looked good right on top of the hitch but the angle was wrong to see the ball. I trimmed the long wings off that would be used to attach to the license plate.
As far as the monitor, I piggy backed the 12 volt switched input to the existing Bluetooth(installed by previsous owner). The brake controller harness 12 volt is always on so that was a no go. I used double sided tape and mounted the monitor to the upper dash to the left of the streering wheel along the pillar. It actually is hidden here and looks good. The wire is hidden nicely as it runs off the left of the unit directly into the rubber strip going down the pillar and then under the dash to the radio area.
The camera activates only when in reverse and the monitor comes on automatically when it senses the camera's signal. The picture does get some interferance at times but for the most part works good so far.
I need to get some pictures and post them.
  #5 (permalink)
Old 04-25-2010, 04:54 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
I am installing an OEM camera with a lockpick so that I can view the camera view through the Nav unit. You have to run the wires through the car but you wont have to mount an additional screen.
__________________
2007 Expedition Limited White Sand
  #6 (permalink)
Old 04-25-2010, 07:45 PM
Where does one find a lockpick?
__________________
  #7 (permalink)
Old 04-25-2010, 08:43 PM
Here you go. FORD 360 LOCKPICK
__________________
  #8 (permalink)
Old 04-26-2010, 08:17 AM
Awesome! Thanks Ticket Bait! They owe you a commission!
__________________
  #9 (permalink)
Old 04-26-2010, 10:57 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Pics please. I am very interested in your install.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #10 (permalink)
Old 05-07-2010, 02:11 PM
Finally got some time to take some pics. Click on any picture to see more. Not 100% happy with the camera location but it avoids drilling into the liftgate and running the wires up through the top and into and down the pillar to the reversre lights. Connected the 12 volt feed directly off the center wire on the trailer harness so it comes on only when in reverse. The reliability of the wireless signal is not 100% but for $74 what can you expect. I tried putting the camera right on top of the hitch receiver and it looked good in that location but the camera was to low to use for backing up to the camper with ball in the way. Used double sided tape and it held strong through the car wash so far.
Click the image to open in full size.
  #11 (permalink)
Old 05-07-2010, 04:51 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
nice job man
you considered mounting that camera inside the bumper cover and just drilling a small hole?
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #12 (permalink)
Old 05-07-2010, 04:53 PM
berry1234's Avatar
Looks good. Not a fan of the camera location. Is there somewhere else to mount it?
__________________
  #13 (permalink)
Old 05-07-2010, 05:28 PM
I'm still looking for alternatives but I definetly do not want to drill any holes. I want the entire install to be removable without a trace if possible. The monitor and camera are doubleside taped and holding well. Any suggestions are welcomed.
Here's a few more shots of the monitor (it's hard to get it to come out clear in a pic.
  #14 (permalink)
Old 05-07-2010, 05:33 PM
berry1234's Avatar
Use the Macro setting for close up pics.
How about mount the camera to the left of the hitch? Opposite of the plug. Is there a license plate adapter?
__________________
  #15 (permalink)
Old 05-07-2010, 05:37 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Ummmmm. I've seen these photos somewhere else...
-- Chuck
Tags
2007, 2009, 2010, backup, blue, camera, eddie, el, expedition, expy, f150, ford, install, navigator, taurus, vr3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
