Trans service by dealer?
Took my 04 to dealer for tranny service(32k miles). I can see where the remove the external filter and the drain plug on the pan, however I can tell they did not drop the pan. I thought there was a screen that needs to be cleaned under the pan and where do they flush the entire system from? They charged me $335.00 for this. 16 qts of sp and external filter. Does this sound ok to you guys? Thanks for any input.
That is true because you are replacing more fluid which costs more. With the machine you are replacing close to 100% of the fluid which is about 16 quarts if I remember correctly. Dropping the pan only removes about 7 quarts.
Dropping the trans pan to change the oil would be the same as dropping the motor oil pan to change the oil. Both have drain plugs on them. My Ford dealer charges between $145- 170 for a hot flush, depending when there is a special going on. Special's would be $145 the inline filter I do because for the last 20K miles I have been draining the pan and adding 8 quarts of fluid every 10K plus changing the inline filter.
The point I was trying to make is instead of unbolting the transmission pan as someone mentioned in an earlier post, just remove the drain plug to drain the 8 quarts. Some owners including myself will drain the 8 quarts every X amount of miles and replace it. I just did this again a few weeks ago using the new LV fluid.
How often are you guys draining the pan and refilling the fluid instead of getting the flush done? Up here in Canada I called 2 dealerships for a quote on getting the tranny flushed and filter changed. One said approx $500 and one said approx $400. I was then going to call some dealerships just across the border and see how much cheaper it would be and if it would be worth it for me to get it done across the border.
But now I am thinking about not doing the flush and just draining the pan but not sure how often it should be done?
Anytime I service the tranny, my preference is to do a pan drop and check the condition of the pickup screen.....then do a flush to move all the old fluid out of the torque converter.
My truck does a lot of heavy towing, so I am a bit fussy!
By the way 1957F100.........I live in Langley also!!
Cheers
Cheers
Cheers
Cheers
If you do it yourself, sir, how do you heat the fluid to get it into (and out of) the converter?
Thanks for your reply!
