98 5.4L Tune Up - Ford Truck Enthusiasts Forums
98 5.4L Tune Up
Old 04-24-2010, 01:55 PM
RoyalFord RoyalFord is offline
RoyalFord is starting off with a positive reputation.
Thumbs up 98 5.4L Tune Up
I'm about to hit 200k in about a week or two. Changing the spark plugs today (last change @ 100k).
She seems like she is much more weaker than she was a few years ago. I've noticed that while I'm in cruise control she is down shifting to 3rd gear a lot on the highway when going up slight hills... which she never did before. Anyone know why this is happening?
What are the major maintenance items that could do to boost her a little bit other than spark plugs? I've changed the fuel filter. Cleaned the air filter. New PCV valve. Do the injectors need to be cleaned? Could I do this myself or professionally?
Any other thoughts?
Old 04-24-2010, 07:48 PM
Postal ET Postal ET is offline
Postal ET is starting off with a positive reputation.
Be careful removing plugs
I have a 98 that had the spark plug blow out while driving. A mechanic said they used a 5 thread spark plug in a 4 thread head. The fifth thread carbons up and can damage the head when removing. He said he does a through decarbon before he pulls the plugs. I bought mine with 52000 miles so I don't think the plugs were even changed but goggle searching after I had the problem came up with what appeared to be quite a few similar problems also from improper tightening. No problems since and now with 140000 miles.
Old 04-25-2010, 12:50 PM
Finished the spark plugs yesterday with no issues. Had to use crazy extensions and unviersal joints. Took about 5 hours.
Misfire in cylinder 5 (P0305) '06 Expedition EB 5.4 3v 83frankenstein250 1997-2006 Expedition & Navigator 10 06-07-2014 07:40 PM
1993 f-150 3.51 5.8L Running a bit rough and Replace PCV Valve? madeinusa 1987 - 1996 F150 & Larger F-Series Trucks 6 05-13-2013 06:58 PM
Help and Opinions on a few 1995 302 F150 Issues ASierkowski 1987 - 1996 F150 & Larger F-Series Trucks 4 07-22-2012 03:52 PM
A few questions on my "new" F150 ASierkowski 1987 - 1996 F150 & Larger F-Series Trucks 3 05-29-2012 07:39 AM
03 Expedition Spark Plugs Change 03fordexpedition 1997-2006 Expedition & Navigator 1 01-28-2008 08:41 AM
Tags
100k, 1998, 200, 2005, 54, 54l, 98, excursion, f150, f250, ford, full, kit, specs, truck, tune, ups
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
