I always use universal synthetic ATF that covers Mercon V. Synthetic seems to be a bit quieter, although that may just be me convincing myself of that.
I'm always a bit nervous going to synthetic well north of 100k, but at least that probably addresses the 'better viscosity' concerns of using the proper stuff.
I have heard of mercon causing more pump noise. I would recommend just sticking with type F. You can find it at any auto parts stores. I even still see it at gas stations.
Being a ford tech, I can tell you that Mercon V doesn't make it any louder than type f from my own experience
You would know better than me. Do you know if ford changed the power steering pump design at all after this era of trucks? I noticed that's when they stopped saying to use type F.
I don't believe they did, but they don't even use type F in dealerships anymore because everything is replaced by Mercon V or Mercon LV. There isn't much to change on a power steering pump other than pressure or pulley size conidering it is just a simple belt driven pump for hydraulic fluid
EDIT: I would also just like to add that Ford PS pumps are just loud in general.
I was more concerned about the seals. That's why I stuck with type F(don't want synthetic with 23 year old seals). Ford pumps are louder due to the design using spring loaded slippers unlike the Saginaw pumps.
