Is it the CV Joint or what?
This past winter I bought an 04 Expy EB. While changing my oil the other day I was inspecting the front driveline and noticed where some grease was spraying from the flange just to the inside of the Rt inner CV joint. It is the flange that bolts together the CV joint to the shaft coming out of the front diff. Is this a common problem, how do you fix it and would this contribute to a sound like an uneven tire wear? Any info would be appreciated. Thanx, fitzy67.
CV Joint?
It doesn't leak from the boot itself but from the flange where it joins into the front differential. Is this related to the CV joint or is it something else?
It shouldn't be too hard to fix or a good shop might do the repair fairly inexpensively.
leaking from front Rt axle housing
Well. I checked under the car to see exactly where the leak is coming from and it is coming from the end of the axle housing just to the inside of the inner rt CV joint flange. It looks to be a seal. So how do I fix this and at what expense? thanks fitzy67. PS I checked the diff lube level and it is good.
stevebigos
1997-2006 Expedition & Navigator
11-17-2013 09:17 AM
fitzy67
06-25-2013 04:33 PM
