2002 Explorer won't go into Park - Ford Truck Enthusiasts Forums
Old 04-24-2010, 09:58 AM
Luke80916 Luke80916 is offline
Luke80916 is starting off with a positive reputation.
I have a 2002 Explorer that won't go into park unless you let it roll for a few inches. started happening once in a while, now all the time. Like the parking pawls are stuck or something. Think this is a transmission issue?any ideas?
Old 04-24-2010, 12:15 PM
F-250 Ranger F-250 Ranger is offline
F-250 Ranger is starting off with a positive reputation.
Have you checked the brake pedal position switch? Have someone stand behind your car when it won't go into park and press on the brake. If the brake light doesn't go on then your switch is bad.
Old 04-24-2010, 12:55 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
........or the fuse. See if activating the brake-shift interlock override on the bottom of the steering column allows you to shift into park.
Steve
2002 explorer no start ignition key greasy hands Explorer, Sport Trac, Mountaineer & Aviator 3 09-13-2016 01:19 PM
2003 Explorer RMeans Explorer, Sport Trac, Mountaineer & Aviator 4 05-16-2016 01:14 PM
Won't come out of park 83FordMan2012 1997-2006 Expedition & Navigator 10 01-06-2013 01:24 AM
2002 7.3l excursion - won't go into park willeo6709 1999 - 2003 7.3L Power Stroke Diesel 3 11-28-2011 11:34 PM
Changed 4x4 cm in my 01 explorer sport, won't go into gear 3sagirl Explorer, Sport Trac, Mountaineer & Aviator 3 12-22-2010 06:10 PM
Tags
1997, 1999, 2001, 2002, 2004, expedition, explorer, f150, f350, ford, park, shift, sportrac, switch, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
