2 problems NEED HELP
Problem #1
1996 Ford f-250 psd
Antifreeze is leaking from the back of the thermostat tube I have changed the orings and the tube but it still leaks
Problem #2
1999 Ford F-250
The problem started at only had reverse took trans to shop bolts came losse put back in also putting a magnetic inline filter on return line worked good then when od it seams to be stuck.in 3rd gear changed all sensers and didn't change a thing. Put in a brand new selinoid pack in and it still didn't change a thing my 96 had this problem and changed the pack and it was.good as new .
Thanks and sorry i typed all of this on my phone
1996 Ford f-250 psd
Problem #2
1999 Ford F-250
