Stock Stereo - How Many Watts? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-23-2010, 02:48 PM
SturgeonHunter's Avatar
SturgeonHunter SturgeonHunter is offline
SturgeonHunter is starting off with a positive reputation.
2004 F250 6.0 PSD - Lariat
AM/FM/Casette/Single CD
How much power does the stock stereo have? It is NOT the premium sound package as far as I know. There are four speakers in total.
Thanks!
Old 04-23-2010, 04:22 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Usually 80 watts...
Old 04-23-2010, 04:42 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
If I'm not mistaken, the stock uses regular transistors rather than FET's, so in reality, the maximum usable musical output is about 10-14 watts per channel.
Old 04-23-2010, 05:28 PM
radzer0 radzer0 is offline
radzer0 is starting off with a positive reputation.
Quote:
Heres a comparison for u guys. I had a 2006 mustang with the plain non shaker 500 system. It was putting out between 4-6watts per channel before clipping. I would guess the internals of that setup were the same just a diffrent faceplate on the unit.
Old 04-23-2010, 06:30 PM
4-6 watts sounds very likely. The 10-14 is the maximum possible using laws of physics.
The key point is that it you are talking typical transistor based amp, the "80 watts" or whatever so many manufacturers claim is maximum theoretical electronic output (re: NOISE), which is very different from music.
Old 04-23-2010, 06:56 PM
Anybody here come accross any info for the 2011 premium sound package wattage would be nice. I dont wanna take my door panels off because i already have a panel noise from the back seat. When my speakers die ill upgrade them. So i think i got another 6 months to a year. But i made sure this time around i got all the options i wanted so that i can keep it for a long time. Only thing i regret not having is the rapid heat. But very few get that down here.
Old 04-24-2010, 05:33 PM
What can the stock speakers handle?
How hard is it to add more power (amp) to a factory setup? Am I better off replacing the stock head w/ aftermarket and an amp? I don't want to blow the windows out, but I would like beter response and more thump.
Old 04-24-2010, 05:38 PM
Ive done it all diffrent ways. If you just want good and loud. I did this on my sky.
Replace the stock radio with a nice pioneer premier unit. They have some of the best onboard amps out there. And put some nice door speakers in.
I personaly ONLY use crossfire. Ive been able to kill everything else in my listening styles but they sound great and dont cost much more than your normal brands (cheaper than JL)
Ive had stock bose systems and the factory speakers couldnt handle it. Not to mention your looking at 6 years of dryrot on what you have.
If your on a budget. Get some upgraded speakers and try them on your factory HU, you will be suprized just what a good set of 3 ways will do compared to old and dry speakers.
If your intrested in crossfire you can check on crossfirecaraudio.com and get a local dealer to talk too. They should be able to do the speakers at 80 or less a set for you to buy and install yourself.
Whats a good stereo on the cheap to replace kickstand03263 1999 to 2016 Super Duty 7 09-04-2014 09:11 AM
stereo removal madsonp 1999 to 2016 Super Duty 0 06-15-2012 11:48 PM
2005 F-150 Lariat - Radio/Stereo removal? wp7456 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 08-05-2010 07:28 PM
Stereo for a stock '65 f100 murrmeister 1961 - 1966 F-100 & Larger F-Series Trucks 21 10-29-2009 04:42 PM
Hooking up an XM receiver to a stock stereo scooterman320 2004 - 2008 F150 1 01-23-2009 09:13 PM
Tags
2005, 2010, 500, 97, f150, ford, navigation, ranger, shaker, specs, stereo, stock, truck, wats, wattage, watts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
