You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey in the book it does not tell me how to change the bulb in the amber lens on my mirrors. I have a 2003 F 250 and I cannot figure what the trick is to get the lens off to change the bulbs in it.
Anyone out there know or have delt with taking the lens out?
There's 4 little tabs that you need to undo to get the rear cover off of the mirror. Access them through the front by adjusting the mirror all the way in and all the way out. Once you get the cover off it's simple.
I don't think you can change the bulbs. They are LEDs on the 03-07. I thought it was just a direct swap for the whole unit.
Maybe a little more research is in order. Do you mean that you have to change the whole lamp assembly or the whole mirror? I'll check it out tomorrow to see for sure.
__________________
Payin it Forward one post at a time
I look at it like this: The advice is free and you get what you pay for; use it or dont my truck still runs fine. From a very well respected friend....Thanks
I replaced mine a couple of years ago. I broke one side on a tree limb. I had to buy the set. I bought the LED kit from Recon. They had great instructions on how to get the old assembly out of the mirror and how to put the new one in.
__________________ 2011 F250 6.7 PSD 4X4 3.55 ELD CC SB Moon Roof Chrome Package NAV Lariat
April 2011 Build, ARE TW Cap, Recon LED Cab Lights, Air Lift Loadlifter 5000,
WeatherTech - Mats, Bug Shield, Mud Flaps; Bed Rug, McGard Tailgate Lock,
Autoenginuity Proline with Enhanced Ford Expansion. 2011 Explorer Limited - Wife's Vehicle 2005 F250 6.0 PSD 4X4 3.73 CC SB Lariat - Sold
Thanks "D". Did Recon offer a different color than the amber?
__________________
I meant the whole lamp assembly. From what I remember (I have 08 mirrors now) it was a complete unit that cost enough to justify purchasing a set from Recon. Of course you also have people who swap out to the Recon sets that sell their used ones for cheap.
The OP stated he wanted to know how to remove the lense to replace the bulb. That's why I questioned it.
I wish I could bump into someone with a set of lenses to fit a 2004 SuperDuty. All I need are the lenses, not the LEDs. My daughter tagged a mailbox with the passenger side mirror -- which I guess was better than hitting the garbage truck that pulled out in front of her. Didn't hurt anything else, but wiped out the amber lens on the mirror. So far as ford ir concerned that entire MIRROR is all or nothing.
Easily replace Clearance Lights on Outside Mirror,F250
On a 2008, F250, To replace the Clearance Lights on the Mirrors:
1) Adjust the Glass Mirror all the way In.
2) Just past the edge is a 1" tab.
3) Push In on the Tab; the Clearance Light Unit should now be free.
4) Pull Out on the Unit and Untwist the Lamp Holders
5) replace the appropriate bulb. Goodluck..Don't pry on it with a screwdriver!
i phoned in the local ford shop and the mechanic said to pry it open with a screw driver..grrrrrr lucky i kept on reading ffs..
Well I was going to say check out this thread that I made last summer.
A heat gun helps to warm up the little wings that hold the lamp in place.
After you get the lamp removed the wings won't be as tight so heat them a little
bit and open them up to keep them in place. http://www.ford-trucks.com/forums/11...or-covers.html
But I see it's been covered. The lamps are LED so you will have to do one of two things.
1. Take the lamp housing apart and try to fix it.
2. Buy a lamp assembly to put in. Check the yards for a broker mirror cover and
see if the lamps is good.
Sean
__________________ Big Cat and not the one on the tail pipe
"How do you eat an elephant? One bite at a time!"
Mods Blue Spring, High Idle(BCP), Coolant Filter,SCT from http://www.gearheadautomotiveperformance.com/
HFCM Drain Plug, Nav System, Leveling Kit, Backup Camera, HID Fog 3000K & Driving Lights 4300K
