1959 ranchero help - Ford Truck Enthusiasts Forums
1959 ranchero help
Old 04-23-2010, 10:51 AM
george d george d is offline
george d is starting off with a positive reputation.
1959 ranchero help
I drive a 59 ranchero. when ever I give it pedal it bogs. perfect idle. perfect starting. any thoughts.
Old 04-23-2010, 02:52 PM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Quote:
Vacuum advance; or
Accelerator pump in the carb.
Check the small vacuum line between the carb/intake and the distributor for leaks.
Rebuild the carb.
Old 04-23-2010, 03:17 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
Bogging down, hesitating, stumbling from a dead stop or when accelerating at speed: Defective accelerator pump diaphram.
Old 04-23-2010, 04:27 PM
Hi thanks for your idea's. The carb was rebuilt by a well known carb shop. The car ran well for a few days and then developed this bogging problem. Is it likely that the accelerator pump or pump diaphram could go bad? Could it be a fuel pump.
Old 04-23-2010, 05:16 PM
jschira's Avatar
If the carb has been rebuilt correctly, the accel pump should be OK. But, they could have installed a bad one, or installed it incorrectly.
Also, there is a little rod that connect the throttle crank to the accel pump. Did this fall off?
Fuel pump is possible but unlikely. Nothing special happens to the fuel pump when you floor the throttle. If the engine eventually "catches up" at higher revs after bogging down, the fuel pump/filter is probably OK.
Check the vacuum advance line. It might have come disconnected.
Also, there is a vacuum advance diaphragm on the distributor. This diaphragm could be bad.
Old 04-23-2010, 05:32 PM
New accelerator pump. The problem is: Age. How old was the new part when it was installed?
This part can lay on a shelf for years, before it finds its way into a carburetor.
Even in a box, humidty...ozone in the air causes it to harden up...the same effect one would expect after 40,000 miles.
Old 04-24-2010, 11:32 AM
Thanks guys I will try your ideas out this weekend. cheers,G
61 ranchero blessed hellrider New Member Introductions 2 05-30-2007 08:45 PM
72 Ranchero wiring shematic rodbender Ranchero & 1961 - 1967 Econoline 1 01-26-2005 08:40 PM
Wanted a Rear Bumper for 66 Ranchero JimBollman Ranchero & 1961 - 1967 Econoline 0 05-31-2004 10:13 PM
'65 Ranchero bed and windshield trim bill young Ranchero & 1961 - 1967 Econoline 1 01-10-2004 03:46 PM
16 inch rims fgor 76 ranchero oregon ranchero guy Ranchero & 1961 - 1967 Econoline 6 12-12-2003 07:51 PM
Tags
1959, 59, accelerator, advance, f100, ford, forum, pump, ranchero, rancho, rod, tech, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
