You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I've got an '04 6.0 that's recently developed an engine performance issue and I was hoping to get some leads on what to chase down this weekend. The truck has 75,000 miles on it and has been trouble-free since new when it comes to the motor. Recently I've noticed that, usually at a stop light, the idle will occasionally get very rough and the normal diesel "clatter" noise becomes rather rough sounding- almost like every other "clatter" disappears if that makes any sense. Up until last night this was happening very infrequently and usually only for a couple of seconds. I wasn't really sure what the issue was then and would rev the truck in neutral and the issue would go away. This has happened a handful of times in the last month or so.
I drive a company car all week and the truck only gets used in the evenings and on the weekends, and last night my wife and I drove it to dinner. The truck cranked and started normally and was operating smoothly until we got out of our neighborhood (about a mile of driving), then the rough running condition described above surfaced and continued throughout the 7 or 8 mile drive. This was the first time that it ran like this for more than a few seconds. The truck was running bad enough that you could feel the misfire or 'chugging' at speed. When the truck would shift into overdrive and the torque converter went into full lock-up, you could really feel this as the engine was lugging. I tried to keep the truck out of overdrive because it was shaking the truck pretty badly. When we came out of the restaurant I thought maybe the issue would be gone but it did it all the way home as well. Throughout both drives the Check Engine Light did not come on.
When I got home I got my DiabloSport Predator because I remembered it has a code scanner in it. I have never checked for codes before so I do not know if these are fresh codes, but there is a P0282 Cyl 8 Injector Circuit Low and a P1000 OBD Systems Readiness Test Not Complete in there.
While I was in the driveway with the engine idling badly for a few minutes, the issue completely went away and the truck smoothed out for a few minutes. It was like someone flipped a switch and the truck instantly ran properly. After a couple of minutes however, the issue instantly returned. I tried to clear the codes with the Predator but they will not go away. I am not sure how solid of a scan tool the Predator is????
I did a lot of searching on here last night because this is bugging me, and the symptoms I saw on here about the ICP sensor make total sense based on what I am experiencing. People were describing to a 'T' what I am experiencing. However, I do not have an ICP sensor code and when I searched for the P0282 that I do have I read about FICM issues here.
The rundown on the truck- '04 F-250 CC 4x4, truck was bought 10-03 and I THINK I remember the build date as 9/03 (maybe 8/03). Automatic transmission, DiabloSport Predator with 60hp tune, MBRP turbo-back exhaust, everything else stock. Oil was changed about 4,000 miles ago, both fuel filters done about 2,500 miles ago.
A few questions:
Could the ICP be my issue even though there is no code for it?
Could the P0282 be coming from an ICP issue?
I've read about early '04 trucks having '03 motors and something about an updated harness for the ICP- could I get more info please?
Is my truck part of the affected group with the wire-chafing I read a little about? If so, could that be causing this and what should I look for?
Does the P0282 immediately point to a FICM issue?
If I could get a few things to check, it would be greatly appreciated. I did a lot of reading on here last night and it is tough to wade through all the threads and get info specific to my truck. I am very mechanically inclined but my experience is limited to gas motors, so I am hoping that some of you can give me some ideas. Like everyone else, money is limited and I would like to avoid the dealer if possible.
I thank you in advance for any guidance offered!
__________________ '04 F-250 XLT Sport Package 4x4- PSD Crew Cab- 8" lift with 37" Toyo MTs, BulletProof Diesel Remote Oil Cooler with 10 micron bypass filtration and Bulletproof EGR Cooler, Edge Insight CTS, DieselSite Coolant Filtration, MBRP 4" stainless Turbo-back exhaust with cat delete, SCT Tuner running Matt's SRL Tune, and other random goodies...
That particular injector code is for a wiring issue---bad wire or coil. I don't think you have a FICM problem because the Predator will show those codes. I use my predator for the same thing but I DON"T run those tunes because they are very destructive. The mileage is nice--best I ever got, but the timing is toooooo high and WILL cause you issues eventually. I speak from experience here. I would check the harness carefully for chafing first.
__________________
Payin it Forward one post at a time
I look at it like this: The advice is free and you get what you pay for; use it or dont my truck still runs fine. From a very well respected friend....Thanks
Thanks for the tips! You didn't mention the ICP sensor so am I to assume that I am barking up the wrong tree with that one? When you say "coil" do you mean the coil inside the #8 injector? Any tips on particular areas of the harness to check for chafing?
I really appreciate the advice!
Nothing indicates ICP at this point. The coils I'm refering to operate the spool valve on the injector itself and are under the valve cover--they are about as big around as a nickel and each injector has two. IIRC there is information in the tech folder where to look for common areas of chafing--#8 is on the drivers side closest to the firewall, and the harness basically runs between the top of the valve cover and the intake manifold. You can see where all the connectors go just above the edge of the valve cover. It's tight to work in that area, but that's a place to start.
__________________
Thanks so much- I will start looking for info on the wire chafing issue and start there. It sounds like that would be easier to deal with than taking a valve cover off to get to the coils.
You can't replace the coils individually as they only come on the injector and you still have to remove the injector to get to the coils. If you don't find wire chafing it's most likely time for an injector, but look at the wiring first. It might be nothing but a pin hole or a loose pin inside the connector. It's a bad place to get to for sure. Might be easier to remove the air cleaner and the two bolts that hold the degas bottle on and roll the degas bottle forward for easier access.
__________________
had the same problem and it was a wire below the turbo that went to senser I think it was the ibp or something like that the wire got cooked by the turbo down pipe inside the protective plastic cover I have a 2004 with 66600 on it
I just had similar problems with my 05 f-250 recently, it turned out to be the ICP sensor, my truck didnt throw any codes, the way you can tell is if the ICP voltage is low, mine was at .82 volts, and for the ICP to be working properly it should be at 1.2 volts or very close to it, check the volts on the ICP if your scanner can read that, my guess is that it is your ICP.
__________________
2005 F-250 CCSB FX4 Lariat PSD
Lots of goodies
2001 F-350 CCLB XL SRW PSD
Stock, work truck
Thanks for the additional input here, guys. Over the weekend I did not have much spare time but I did take a quick look at my wiring. I found a few places where I could see that chafing could be a problem but didn't find any broken wires. I drove the truck quite a bit yesterday and all was well. I'll be keeping an eye on this and will see if my scanner will read ICP voltage- I'd LOVE for it to be something easy like that versus an injector issue....
Here's a good article on the wire chaffing issue: Diesel Technician Society
I've never seen one this bad but obviously it can happen
__________________
