2005 F250 shuts off on its own for no reason
Old 03-06-2017, 01:44 PM
BGDDYKWL's Avatar
BGDDYKWL
BGDDYKWL is offline
This has happened twice now, both times immediately after towing. I'll start it, begin to accelerate, and it will just putter out. It'll start right back up but it'll putter out again. After 20-30 minutes it'll start (and run). I have an edge programmer and it doesn't turn on when this happens. I get a turbo warning on it that the psi is at like 43/46 even though I'm essentially at idle so it seems to be getting a faulty error thinking the turbo is under too much load. Any thoughts as to what the problem might be would be much appreciated. Thanks.
Old 03-06-2017, 04:20 PM
Bumblebee04's Avatar
Bumblebee04
Bumblebee04 is offline
Start by load testing batteries and checking connections including grounds. Then check alternator output to be sure its good.
Old 03-06-2017, 06:01 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Anything to monitor live data such as icpv and ipr% when it dies?
Old 03-06-2017, 09:20 PM
bismic's Avatar
bismic
bismic is online now
Received 2,483 Likes on 1,722 Posts
try running w/ the EBP unplugged also.
Old 03-07-2017, 01:47 PM
Watcher58's Avatar
Watcher58
Watcher58 is offline
Dont have a clue if this related but a buddie (God rest his soul) had an F250 and had a camshaft sensor issue. It would just cut off.
Old 03-07-2017, 01:51 PM
Watcher58's Avatar
Watcher58
Another friend's experience-when his AC seized after towing, it would not restart at all. I wonder if one can be in the process of seizing but not completely and be adding more and more load on your engine until it fully seizes and then wont start at all....just a thought
Old 03-07-2017, 02:19 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
Doubt it has anything to do with the A/C compressor....need to get some gauges to monitor vitals as it dies and wont re start.....
HPO issue?
cgholson192
09-01-2015 03:44 AM
mrwrench
06-02-2014 09:15 PM
ssnbdr75
04-27-2012 10:39 PM
jjwilt
05-18-2011 11:46 PM
fin1
04-05-2008 01:11 AM
Quick Reply: 2005 F250 shuts off on its own for no reason
